XJ XJ XJ Cherokee Cheap Mods XJ XJ XJ - Page 17 - JeepForum.com
post #241 of 416 Old 03-20-2011, 01:07 PM
keepishop
1989 XJ Cherokee
Miniwriteup: Newer style shift bezels for renix rigs. If you have the shift bezel with a straight sheet of thin plastic like both of mine came with, you probably hate it. Mine both cracked and got really ugly, and just swapping one from a new rig didn't quite work. New ones protrude forward more and make a nasty CRACK noise whenever you shift into park. Simple solution.
Pop off the handle (be careful). Pop off the bezel. Loosen the screw in the small green circle to give you some room to work. Cut the chunk of plastic in the big green circle. I cut it out completely, but you could probably get away with only a half inch or so of trimming.
Bam, Newer style shift bezel works great now. Get one from a 96, they look rad.
fin.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #242 of 416 Old 03-22-2011, 03:14 PM
95whiteXJ
1991 XJ Cherokee
Originally Posted by brand0nlp
few mods here!
some a little more pricey but its all well worth it.!
Bed lined floor, for $70 not to bad. its the duplicolor roll on kit from advanced autoparts. it durable to
Next up painted the front and rear diffs. whats needed 2 cans spray on truck bed liner (duplicolor) and cherry red engine spray paint.
My new 4 wheel drive handle. cut off the old rubber handle heated the metal, straightend it. and then cut it off where the metal rod was round. used my tap and die set. spent 40 bucks to buy the handle and its as good as new.
next up Cb antenna mount. mount was 15 bucks just bolted into place drilled a few holes and now the mounts hidden.
and last for now my LED cluster and instrument lights. cost 24 dollars for all the lights.
if you want any info on what i did pm me!
Love the LED gauge lights.....where'd you get them from? These are actually on my list of cheap mods..along with white gauge face overlays and a chrome gauge bezel...thanks for your time
95whiteXJ is offline
post #243 of 416 Old 03-22-2011, 03:21 PM
95whiteXJ
1991 XJ Cherokee
Originally Posted by comanchetrooper
I havent done it but the thicker steering links and swaybar from a V8 zj bolt right up
also Grand seats bolt up to 97+ pedastals
and on older xjs and mjs swaping in a 97+ front clip is farliy inexpensive
So a 97+ front clip will bolt up to my 95?!?!
post #244 of 416 Old 03-22-2011, 03:31 PM
95whiteXJ
1991 XJ Cherokee
Originally Posted by patman2613
How big of a lift? I did a 2" for like $75
How?!?! Lol
post #245 of 416 Old 03-22-2011, 06:27 PM
ctm9191
1989 MJ Comanche
Originally Posted by 95whiteXJ View Post
How?!?! Lol
x2
Originally Posted by NHRubi View Post
It's a broken kanibulen pin in your flux capacitor, take your rig off the street immediately
ctm9191 is offline
post #246 of 416 Old 03-22-2011, 06:30 PM
keepishop
1989 XJ Cherokee
How?!?! Lol
Go read rocklizard's site. He did 4.5 for about that.
Bleed or Quit.
post #247 of 416 Old 03-23-2011, 08:59 PM
PlatinumNiner
Header panel and fenders are needed for the swap to be done right. Im in the middle of doing mine now.
PlatinumNiner is offline
post #248 of 416 Old 03-24-2011, 11:51 AM
95whiteXJ
1991 XJ Cherokee
Sweet!! Thanks for the info!! Probably gonna do this very soon!! Thanks for your time.
post #249 of 416 Old 03-24-2011, 04:17 PM
PlatinumNiner
No problem its a great swap i love the look of the newer front end on the older tail gate and tail lights.
post #250 of 416 Old 03-24-2011, 06:09 PM
95whiteXJ
1991 XJ Cherokee
You and me both buddy!!
post #251 of 416 Old 03-27-2011, 08:48 AM
15tcherokee
Originally Posted by vx1kxj View Post
I would really like to know how you did the hookups in your rear cubby.
15tcherokee is offline
post #252 of 416 Old 03-30-2011, 08:22 PM
-DOM-
keep it goingggg!!
thinking about doing the LED mod looks sick
-DOM- is offline
post #253 of 416 Old 04-06-2011, 07:43 AM
ArmySniper_87XJ
1990 XJ Cherokee
Mad props to all of the stuff yall have done to your jeeps. I just returned from Iraq about 2 weeks ago and i traded my 2002 Dodge Durango R/T 5.9 for a 1987 jeep GC Limited and some cash.. I want to lift this thing up about 3 inches maybe more, And get some good 32" tires... Any suggestions?? Thanks in advance guys!
UNITED STATES ARMY
"If you CAN read this.. Thank a teacher//If you ARE reading this..Thank a SOLDIER"
ArmySniper_87XJ is offline
post #254 of 416 Old 04-06-2011, 07:45 AM
dukie564
1995 XJ Cherokee
I'll only give you suggestions if you never refer to a XJ Cherokee as a Grand Cherokee (ZJ) again
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #255 of 416 Old 04-06-2011, 07:57 AM
ArmySniper_87XJ
1990 XJ Cherokee
Fair enough... Again new to it all...
UNITED STATES ARMY
Cheap yj mods love2crwl Cheap Tricks & Fixes 36 02-04-2017 05:22 PM
cheap 4.0 mods? redneckwithajeep Engines & Drivetrain 17 01-04-2015 02:33 PM
cheap xj mods?? hoot20 Cheap Tricks & Fixes 0 05-25-2009 02:52 PM
CJ-7 Cheap Mods GoldenEagleGa Cheap Tricks & Fixes 1 02-06-2009 11:53 PM
Cheap exhaust mods? apoto11 Cheap Tricks & Fixes 20 10-16-2008 05:23 AM
