-   Cheap Tricks & Fixes (http://www.jeepforum.com/forum/f46/)
-   -   XJ XJ XJ Cherokee Cheap Mods XJ XJ XJ (http://www.jeepforum.com/forum/f46/xj-xj-xj-cherokee-cheap-mods-xj-xj-xj-184475/)
xj-xile 08-12-2005 04:07 PM
Others are welcome to contribute, but please... POST PICTURES!!! Or... PM me & I'll post the pictures (don't worry, I'll be sure to put your name on it, so people know it was your idea & not mine).
Note: Remember these should be cheap mods.
I would start with Balloo93's cardomain site [includes: transmission cooler install, hitch install, DIY bored TB, corner light covers, & cool air intake].
These are threads already covering XJ cheap mods. In order of importance/usefulness (IMO):
1) oil catch can for blowby by xj4play
2) idea thread (no writeups) [rear swaybar removal, fender trimming, Balloo93's page again]
3) http://www.jeepforum.com/forum/f11/favorite-do-yourself-trick-mod-151428/
4) http://www.jeepforum.com/forum/f11/cool-simple-mods-73114/
Mods for any Jeep (mostly single posts, rather than a whole thread to read thru):
1) [tie down tabs] http://www.jeepforum.com/forum/showp...5&postcount=66
xj-xile 08-12-2005 06:51 PM
Cold Air Box (pics, too)
3 Attachment(s)
This is my interpretation of a cold airbox. Cost~$10
Cold airbox prevents underhood hot air from making intake air excessively warm--cooler air=more horsepower, better throttle response, (maybe) better gas mileage. For more info about cold air, see this link, this link, and the place where I got the idea, this link
EDIT: Marcus has added his interpretation of a cold airbox to his "Go Jeep" website: Marcus' airbox insulation (scroll down a little, past the manifold heat shield).
EDIT2: I should add that some of the tape is coming off my airbox--the 'shielding' isn't exactly permanent, the way I've done it. Marcus' version is faster, easier, and simpler to maintain, I suspect.
EDIT3: a version by 00xj54, removing the airbox & using a cone filter + heat shield.
Parts/supplies:
-one roll of noninsulated thermal tape (thin strip-aluminum with sticky backing) from Home Depot [heating/air cond (HVAC) section of the store]
-one roll of insulated thermal tape from Home Depot (aluminum foil backed with foam) [same section of the store]
-smallish (10" x 6") piece of (flexible) windshield sunshade/exhaust wrap/heat shielding
-3 medium-length zip ties
-tin snips to cut the aluminum tape
You need not use both kinds of thermal tape. The foam-backed stuff insulates better, but the aluminum tends to detach itself from the foam. I used the regular aluminum tape to reinforce the insulated stuff.
1) remove airbox, clean it thoroughly, cut pieces of aluminum tape to fit shape of airbox (time consuming--probably 1 hr.), then reinstall airbox
2) remove & clean air hose between throttlebody & airbox, then reinstall
3) wrap piece of sunshade/exhaust wrap/heat shielding around the air tube, & secure with zip ties
I didn't use tape on the air tube b/c tape would not stick to it. The wrapping I used was some stuff I saw fall off another guy's exhaust on the street one day (I tried to catch up to him, but he got on the highway, so I went back & picked up the exhaust wrap, & I still have some of it today :D ). Some guys use a cut-up sunshade to cover the whole airbox, but I thought it would get in the way of the clips that hold the lid on, & the little CCV tube, so I used tape, which can be cut to a more precise shape--but it takes much longer to do. Pics:
xj-xile 08-12-2005 07:29 PM
**My favorite** Intake Manifold Heatshield
1 Attachment(s)
This was probably the second or third mod I did after I bought my XJ, & it is the one that has produced the most perceptible result. Here is the website where I first got the idea (pics on this site--I'll post my own pics later): http://www.angelfire.com/my/fan/manifold.html.
Cost~$25 or a little less (the way I did it).
Parts/supplies:
-roll of thermal shielding: Thermo-Tec, part number #THE-13575 from SummitRacing ($17.88 at time of this writing, excluding shipping costs). Or, you could fab a shield out of sheetmetal if you have some, like GoJeep did. I prefer the flexible stuff, because you can just jam it in under the manifold--with the sheetmetal, you have to remove the airbox & possibly some other parts just to get it in there.
-metal strapping kit [see picture] (in the exhaust section at AutoZone & other stores)--maybe $3.00? Or, go the route that Dino took (which will double the cost of this mod), & buy Thermo-Tec's strapping kit from Summit Racing ($18.88 at time of this writing).
-one or two screws with washer & nut (should come with the metal strapping kit if you get the same one I did [see picture])
-tin snips (to cut the metal strapping to length)
Procedure:
1) follow the link to GoJeep's intake shield to see the shape & dimensions you need to cut the heat shield to (in millimeters) [I'll update this with the figure in inches later]
2) shove the heatshield in underneath the air intake manifold--if you cut it right, it will probably stay there without any support, but
3) to secure it, you should strap it to the intake manifold by means of the metal strapping--run the strap underneath the manifold, cut it to the right length with tin snips, & use the nut & screw to secure the ends of the strap.
xj-xile 08-23-2005 09:18 PM
Fire Extinguisher
First, an article on the why and how of using an extinguisher in a trail vehicle.
And a thread on fire experiences/tips.
Small extinguishers are cheap ($10) & will come with a mounting bracket. You have to decide where to place it though.
Other parts/supplies: 1 screw, 1 nut (no larger than #10 x 1/2"--I bought a $0.99 packet of [8] #10-32 x 1/2" screws & nuts f/Home Depot), and a screwdriver. If you are not mounting it where I did, you'll want beefier screws, but the bracket on my extinguisher wouldn't have taken anything larger than a #10 anyway.
Generally speaking, you want to be able to get to the extinguisher quickly (obviously), so take that into consideration when you're looking for places to mount it. But you also have to mount it securely--the bracket that comes with it won't keep it in place if you get into a car accident!!... unless you mount it under a seat, in which case you might get away with just using the bracket, though a zip tie around the bottom of the extinguisher wouldn't hurt (bracket usually holds the extinguisher from the top, but not from the bottom--when you need it, yank it from the top & it will slip out of the zip tie at the bottom).
The most popular location is under the left side of the driver's seat--easy to get to quickly, & tucked out of the way. Courtesy of BlueGerbil: http://www.jeepforum.com/forum/showp...65&postcount=4
http://i8.photobucket.com/albums/a43...e/maglite1.jpg
http://i8.photobucket.com/albums/a43...e/maglite3.jpg
I couldn't do this b/c of my leather seats (they're shaped differently than the cloth seats--no room under there). I didn't want it in the cargo area, lest it break loose & smash some thing or person. So, I put it under the rear seat, which, handily, has a cross brace with mounting holes already available. This is under the rear seat, driver's side (the tire jack takes up room on the passenger side) & you can see the holes in the cross brace, which I used to mount the extinguisher:
http://i8.photobucket.com/albums/a43...rtheseat01.jpg
Here it is installed (the thing on top is my WalMart 0/2-guage jumper cables, so you can see there's room for more):
http://i8.photobucket.com/albums/a43...e/a8e5d9d4.jpg
Other locations:
http://i8.photobucket.com/albums/a43...tinguisher.jpg
http://i8.photobucket.com/albums/a43...inguisher2.jpg
creature 08-24-2005 10:00 AM
heres my infamous ping pong paddle CB mount, notice you can't see the ping pong paddle* because it was tucked away above the headliner
http://i21.photobucket.com/albums/b2...2/100_1036.jpg
so it goes
Ping Pong Paddle
Headliner
CB Radio
*You can use almost anything instead of a ping pong paddle, plywood would probally also work fantasticly aslong as it can spread the weight of the CB across the headliner
And bedlined rear bumper No More Scratches!
JIMBOJAMES 09-01-2005 03:05 PM
Nice I think I am going to mount my mag light in the back. I like that idea.
NEWtoTHEjeepLIF 09-04-2005 02:39 AM
Talk about a projectile (sp).....That mag light it not that secured and sitting heavy side forward... if you get in a front in collison that will be a 3D missle instead of a 3D Mag......
JMHO Good Luck Happy Jeepin!
xj-xile 09-07-2005 12:51 PM
Yeah, I'd have to say I wouldn't personally mount it in the back (unless you box it up or put it behind the spare tire, or something so it won't get loose in an accident...).
jfiscus 09-12-2005 01:38 PM
cheap mods I've found
My mods:
How to cut your fenders for fitting larger tires:
http://www.jeepinohio.com/kb.php?mode=article&k=3
How I lifted my XJ 3" with used parts (costs about $100):
http://www.jeepinohio.com/viewtopic.php?t=847
How to cut your front fenders to fit TJ flares:
http://www.jeepinohio.com/viewtopic.php?p=8349#8349
You can also get 1" of rear lift by replacing your stock XJ shackles with stock MJ shackles, you can buy these at a junkyard for around $25/set.
Not mine, but good XJ cheap mods:
~2" budget boost:
http://www.rocklizardfabrications.co...dget_boost.htm
~4" budget boost:
http://www.lunghd.com/Tech_Articles/...udget_Lift.htm
onboard air (around $100):
http://www.off-road.com/jeep/cheroke...boardair2.html
removable doors:
http://www.projectxj.com/mods/doorless.htm
http://www.myxj.net/tech/doorless/
make your own coil spacers:
http://www.go.jeep-xj.info/HowtoFrontSpacer.htm
front axle posi-lock:
http://home.earthlink.net/~stevenschreiber/cabledis.htm
$5 sway bar discos:
http://www.rockcrawler.com/techrepor...ects/index.htm
removing your rear 1/4 panels for more tire clearance:
http://www.naxja.org/forum/showthrea...lower+quarters
make your own snorkle:
http://www.naxja.org/forum/showthrea...memade+snorkel
make your own TC drop kit:
http://www.go.jeep-xj.info/HowtoTCdrop.htm
sneaky snorkle:
http://www.madxj.com/MADXJ/technical...tomSnorkle.htm
more snorkle stuff:
http://www.naxja.org/forum/showthrea...t=50489&page=1
change your own diff fluid:
http://www.4x4xplor.com/diff-service.html
xj-xile 05-04-2006 12:47 PM
One I forgot earlier: switching to a larger oil filter for (possibly) better filtration, and 1/2 qt. - 1 qt. greater oil capacity. The explanation/writeup is here, courtesy of MadXJ.com: http://www.madxj.com/MADXJ/technical...Conversion.htm
All you do is buy a larger filter with the right threading to match the OEM filter. The NAPA filter part number is 1515. Mobil1 filter part number M1-301. The Bosch filter number is 3500. Not sure about other filter brands, but see the linked article for more info.
Doesn't cost any more than the usual filter. Falls into the "why not?" category.
96JXJ 05-05-2006 02:55 AM
Cowl intake mod.
http://i6.photobucket.com/albums/y24...J/HPIM0188.jpg
http://i6.photobucket.com/albums/y24...J/HPIM0187.jpg
JIM.
96JXJ 05-05-2006 02:58 AM
Hood vents.
http://i6.photobucket.com/albums/y24...J/HPIM0181.jpg
http://i6.photobucket.com/albums/y24...J/HPIM0185.jpg
JIM.
96JXJ 05-05-2006 03:01 AM
My CB mount.
http://i6.photobucket.com/albums/y24...J/MVC-030S.jpg
No ping pong paddle needed. JIM.
96JXJ 05-05-2006 03:03 AM
How to keep the drag link TRE from hitting the quick disco.
http://i6.photobucket.com/albums/y24...J/HPIM0175.jpg
http://i6.photobucket.com/albums/y24...J/HPIM0174.jpg
JIM.
xj-xile 05-05-2006 11:14 AM
Headlight Wiring Harness
Haven't done this one yet, myself, so this is all borrowed.
The stock XJ wiring harness is quite inefficient. Owners report 2 volts less power at the lights than what should be there. Also, owners who upgrade to Hella, IPF, or Cibie H4 headlight housings/bulbs are sometimes disappointed, if they haven't also upgraded their wiring harness. The stock wiring just doesn't pump enough juice, and may even fail when used with high-powered bulbs. Purchasing a harness can be expensive, so several forum members/users have made their own--usually for around $50.00.
in no particular order...
1) DefaZ's diagram, writeup, and genesis (see p. 2 for pic of relay mounting location). I've linked the diagram separately because the link in the original writeup is now broken. I've also attached it to the bottom of this post.
2) Patrick Norton's pair of writeups (with pics) on the harness and headlight upgrade: page 1, & page 2.
3) GoJeep's headlight loom upgrade--parts list, diagram, and pics.
http://i8.photobucket.com/albums/a43...e/1b437894.jpg
The time now is 12:25 PM.
