Wrangler Door Hinges rusted - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Wrangler Door Hinges rusted
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 11-02-2011, 09:27 PM   #1
wisconsinalex
Hey, okay so I bought my Jeep used and the dude I got it from didn't take the doors off much(apparently) so the pins are all rusted and won't come out. I've tried WD-40'ing it and that won't work... Any advice?
HeyHey it's Alex!
The Iron Blueberry- 1976 Ford F100 Ranger XLT
The Thing- 1997 TJ Wrangler (it's a love/hate kinda thing)
wisconsinalex is offline   Reply With Quote Quick reply to this message
Unread 11-02-2011, 10:31 PM   #2
ejeeperguy
1982 CJ7
Bp Plaster!!!!!!!!!!!
All hail the Plaster gods. This stuff is what you need.Tape off where you don't want hit and go to town.Everbody sells it.I got a two for deal from Autozone.So I always keep two cans in the man cave.Let it sit for 5 or 10 mins should do the trick.
ejeeperguy is offline   Reply With Quote Quick reply to this message
Unread 11-02-2011, 10:51 PM   #3
wisconsinalex
Sweet! Thanks
HeyHey it's Alex!
Unread 11-04-2011, 02:46 AM   #4
fuzz2010
Might get confused about that, I think he means PB Blaster.
My Jeep was like yours, I sprayed with PB and when that didn't work I took a punch and hammer to the bottom side of the door pin. If that doesn't work you need a bigger hammer. If your worried about taking the paint off fold up a paper towel a bunch of times and put it in between your brass and tub, and go slow if your really worried about it. Once you get them off take some emory cloth to the door pin and the hinge side to clean out the rust, and reaply some PB to stop it from rusting again.
Once you get them off the first time it will lots easier the next hundred times.
fuzz2010 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2011, 12:58 PM   #5
fillerup
After spraying the heck out of the pins I had to put a jack under my door to push up on it.
Worked great , a little upward force and wiggle the door back and forth they came right off.
fillerup is offline   Reply With Quote Quick reply to this message
Unread 12-01-2011, 01:15 PM   #6
caztj
I ended up using the Jack method too! It does work when nothing else will.
caztj is offline   Reply With Quote Quick reply to this message
Unread 12-01-2011, 03:47 PM   #7
wisconsinalex
And did the jack bend the door frame at all?
HeyHey it's Alex!
Unread 12-01-2011, 05:11 PM   #8
Jason
You only really need to apply enough force to maintain some upward pressure on the door, while you persuade the hinge pins out. So if this is done with some common sense, there shouldn't be a problem. I'd stick a block of wood in between the jack and door.
I use a little anti-seize. I don't believe that PB would stay on the hinge pin long enough to help with removal.
Jason is offline   Reply With Quote Quick reply to this message
Unread 12-03-2011, 07:48 PM   #9
tyler_lapointe
Best thing and simplest that I have always done is just put a 2X4 in between the door ad the frame while the door is slightly open and lift from the back, laws of physics. It's insanely easy to get any stuck door as well as won't cause any damage, the 2X4 with break or get damaged before your jeep!
tyler_lapointe is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 03:01 PM   #10
sean007r
love the post
had the same problem with mine
had tried the floor jack trick ASAP to no avail (12 months ago)
hit with all kinds of lube including PB Blaster... still nothing
Then today I tried it again
but this time, once the floor jack started to actually lift the whole vehicle by the door hinges I stopped and waited
with in a few minutes I could start seeing the space between the hinges grow
I then started hitting the pins with Liquid Wrench and with a few more minutes POP
the door came free
Lessoned learned though... either hold on to your door the entire time or use something to "hang it" so that when the door finally pops off the hinges it doesn't land on the floor and crease the edges :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-( :-(
while I had the doors off I hit the hinge pins with sanding paper and antisiezed the crap out of them! :-)
sean007r is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 05:24 PM   #11
jlp437
After trying jacks, hammers, lubricants and penetrants, I used an air hammer and taped all surrounding areas to avoid scratching
jlp437 is offline   Reply With Quote Quick reply to this message
