WJ Junkyard 6" rear coils. - Page 3 - JeepForum.com
post #31 of 37 Old 03-18-2013, 06:38 AM
vincejeep
sorry, this is the only one i took, but remember the rear coils are not stock tahoe, they are eibach lowering springs for tahoe, stock ones will lift at least 2" higher
sits on 245/70r16(stock size)with home made 2.5" crap spacer in front
my advice:if you want cheap good lift without problems don't go higher than that or you will have issue with front drive shaft, death wobble maybe brake lines, need of a a-arm spacer. my friend got a 4 inch on his limited and spent 2k$ to get it right on the road and trouble free
vincejeep is offline
post #32 of 37 Old 03-18-2013, 10:11 AM
jims00wj
I was just curious. Looks pretty good for a cheap lift.
jims00wj is offline
post #33 of 37 Old 03-18-2013, 06:44 PM
DJeepinOK
Anybody find out if this works for tj's?
Yellow Jeep Club Member #√(-1)
DJeepinOK is offline
post #34 of 37 Old 03-20-2013, 01:28 PM
cnacowboy
how did you mount ur cb antanna
cnacowboy is offline
post #35 of 37 Old 04-04-2013, 10:21 AM
99WJLimited
Does anyone know if there are parts from stock cars/trucks at the junk yard that would give between 2"-3" of lift for both the front and rear. I am dying to lift my WJ but cannot afford to do much right now and I'm not down for spending over $100 on a couple pieces of plastic to stick in!
99 Grand Cherokee Limited 4.7 45RFE Quadra-Trac II Dana 30 Dana 35 Firestone Destination A/T 245/70R/16
“If I had no sense of humor, I would long ago have committed suicide.” ― Mahatma Gandhi
99WJLimited is offline
post #36 of 37 Old 04-06-2013, 06:04 AM
vincejeep
for tj you can put v8 zj upcountry coils in front with a few rubber insulator from junkyard for up to 3-3.5" and for the rear i think you can set front coils for 3"(works on zj)
post #37 of 37 Old 04-06-2013, 06:05 AM
vincejeep
magnet base
anyone run 3" coils (front) & 2" spacers (back)? mikey6345 Tires & Wheels 4 08-29-2007 09:23 PM
Possible to use 5.5" coils with RE4.5 SF? nc4x4 Tires & Wheels 27 01-23-2006 06:04 PM
Rusty's 3" coils vs. OME HD coils? hillcityTJ Tires & Wheels 7 01-18-2006 09:04 PM
2.5" XJ Coils? DroopyDog Tires & Wheels 2 12-10-2005 08:05 PM
2.5" OME coils jonster Tires & Wheels 5 03-19-2005 04:30 PM
