WJ Junkyard 6" rear coils. - Page 2 - JeepForum.com
post #16 of 37 Old 04-13-2011, 11:16 AM Thread Starter
iluvtruenos
Originally Posted by jusjammmin View Post
got some coils.....turns out they dont fit on mine....the top of the spring is too narrow for the top mount..i tried grinding and grinding.. i might just end up pulling out the plasma cutter
That's interesting. Are you talking about the thinner coil or the thicker one? On mine, the thicker coil was at the top, and fit right in the frame mount bucket. The bottom both "popped" in place when the Jeep was settled on the coils.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #17 of 37 Old 08-07-2011, 09:02 PM
mrJ
2002 KJ Liberty
any updates? buying my coils tues and dont know to get iro or expeditions for the rear
Build In Progress...
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline
post #18 of 37 Old 10-06-2011, 08:11 AM
JASON_77
2wd or 4x4 expedition rear coils?
~Jason~
1998 TJ 4.0L,2.5 Skyjacker,1.25 JKS, MML,Flat belly,35-12.50-17 Mud Grapplers,17x9 Classic Locks,HP30/8.8 4.56
2000 WJ 4.7, 6.5" LA, 33's, 4.56's
JASON_77 is offline
post #19 of 37 Old 10-18-2011, 05:58 PM
00WJHEEP
x2
00WJHEEP is offline
post #20 of 37 Old 10-22-2011, 11:45 PM
ColoradoCole
You think this might work on the TJ
ColoradoCole is offline
post #21 of 37 Old 10-23-2011, 10:38 PM
mckoolkid
anyone find coils for the front?
mckoolkid is offline
post #22 of 37 Old 10-26-2011, 02:00 PM
glen6251
im curious about the tj also
My build Thread -
glen6251 is offline
post #23 of 37 Old 03-21-2012, 05:02 PM
PHARIS88
Are there any coils for the rear that would only be about 3'' of lift? As well as lifting the front 3" from junkyard parts?
Anybody can be become an American, you have to be BORN TEXAN!
PHARIS88 is offline
post #24 of 37 Old 08-01-2012, 08:56 PM
WJ910
did anyone find out if there were junkyard coils for about a 3 inch lift?
WJ910 is offline
post #25 of 37 Old 10-18-2012, 04:05 PM
grin
to the OP -- any feedback on how stiff these are after 6 months of use? again with the 2x4 or 4x4 expedition questions though...
TIA!
grin is offline
post #26 of 37 Old 10-19-2012, 11:31 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
try ford t-bird coils
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #27 of 37 Old 10-25-2012, 04:18 PM
416469
Do you need to adjust the air pressure in the tires to compensate for the higher center of gravity and the increase in the shock return rate?
416469 is offline
post #28 of 37 Old 01-05-2013, 10:43 AM
mickeyd411
I would be very careful with that, too much high or and you could wind up with serious safety concerns. Too high and you decrease contact patch and therefore available traction, too low
And you run the risk of pulling the tire off of the rim, though we all know lowering can help in some off road situations. Just don't go too far and don't overheat your rubber. A blowout is no fun, but at the worst time in a lifted vehicle it can roll you.
mickeyd411 is offline
post #29 of 37 Old 03-16-2013, 07:09 AM
vincejeep
i found an eibach 2"drop for 04 tahoe and these coils with a minimum of cutting on the ends gave me a 2.5" lift in the rear and for the front i ended up using 3" exaust tube to lenghten the coil tower and add extra lower insulators on top
so rear tahoe/suburban coils is a cut to fit and the ride is smooth as stock on mine
vincejeep is offline
post #30 of 37 Old 03-17-2013, 08:56 PM
jims00wj
Got any pictures of the install?
jims00wj is offline
anyone run 3" coils (front) & 2" spacers (back)? mikey6345 Tires & Wheels 4 08-29-2007 09:23 PM
Possible to use 5.5" coils with RE4.5 SF? nc4x4 Tires & Wheels 27 01-23-2006 06:04 PM
Rusty's 3" coils vs. OME HD coils? hillcityTJ Tires & Wheels 7 01-18-2006 09:04 PM
2.5" XJ Coils? DroopyDog Tires & Wheels 2 12-10-2005 08:05 PM
2.5" OME coils jonster Tires & Wheels 5 03-19-2005 04:30 PM
