wheelin" with seatbelts - JeepForum.com
post #1 of 5 Old 10-24-2004, 08:41 PM Thread Starter
Why J?
Why J?'s Avatar
Ever go to look where you are going and BAM you get caught by the seat belt? I hate that. one way to fix it is to put the shoulder harness behind you, the other is to use a clip on the seat belt to keep it from locking up. what i did was to use the rear seat lap belts. they are perfect, direct bolt ins and the right length. I have had my rear out for some time in the attic and i was up there looking around and i saw them and thought it would work, used them last night worked great.
Why J? is offline
post #2 of 5 Old 10-24-2004, 08:55 PM
dakuda
Admin
dakuda's Avatar
Personally, I would rather have them lock up as they are designed to and be inconvenienced a few times.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #3 of 5 Old 10-24-2004, 09:59 PM
Yeller'00sport
my problem with seat belts is when you stop and you are kinda off kilter a little and you get out for what ever reason. The problem I have is when I get back in. I can never buckle back up until I am absolutely flat it seems. I always buckle, but I'm afraid the worse will happen while trying to get the seatbelt to release enough to buckly up.
Yeller'00sport is offline
post #4 of 5 Old 10-25-2004, 12:33 PM
denverd0n
Slipping the shoulder strap behind you for a moment while you look is fine, but leaving it there while you're 4-wheeling is DUMB! Most of the Jeep clubs I know of REQUIRE seatbelt use while on a trail run. There is a very good reason for that rule!
denverd0n is offline
post #5 of 5 Old 10-25-2004, 10:22 PM
bockwho
bockwho's Avatar
My grandfather had a plastic thing that slid over the sholder web belt with a little red slider in it that you could lock the seat belt so that it would lay loosly across you. if you didnt move the red thing the seat belt would not retract clamp would work the same way .
00 TJ Sport
96 XJ classic
65 corvair (if you don't know don't ask)
My Life is Hard
bockwho is offline
NJ wheelin shorestyle031 General Jeep & Off-Road Equipment 2 07-31-2008 12:55 PM
Best rig for wheelin? Timberwood General Jeep & Off-Road Equipment 50 05-14-2007 10:14 PM
Manaully Unlocking Seatbelts?? TellyDSP General Jeep & Off-Road Equipment 3 06-12-2006 11:21 PM
Why don't we have a "wheelin pics" thread like the XJ guys Texas TJ General Jeep & Off-Road Equipment 21 11-08-2005 05:25 PM
yj seatbelts into tj seats mflave007 Cheap Tricks & Fixes 2 05-29-2005 08:39 PM
