Water in the drivers floor board - JeepForum.com
post #1 of 8 Old 01-04-2013, 07:28 PM Thread Starter
trakwrkr
2000 TJ when it rains I get heavy pooling on the drivers floor board, I actually empty my floor mats at each destination.
I've tried looking when I stop, but its hard to pin point. Everything I've seen is for the passenger fixing the passenger side.
I'm open to suggestions!!! Please help tired of wet feet!!
trakwrkr is offline
post #2 of 8 Old 01-05-2013, 09:04 PM
TheYJnut
Soft door or hard doors???
TheYJnut is offline
post #3 of 8 Old 01-07-2013, 12:26 PM Thread Starter
trakwrkr
Full hard doors, with soft top
trakwrkr is offline
post #4 of 8 Old 01-12-2013, 04:49 PM
seattle_yj
My hard top and full doors leak at the door weather stripping. I would run the hose and check the seals on yours.
seattle_yj is offline
post #5 of 8 Old 01-16-2013, 10:56 PM
jeepin85
Water leaks from the cab air intake in front of the windshield. Try covering it when you park it, if the leak stops then you know where its coming from.
jeepin85 is offline
post #6 of 8 Old 01-18-2013, 05:50 AM
seuss79
I Restored the body on my yj, and mine now does it too. I pinpointed it to water coming in through the windshield hinge bolt holes. I really don't want to take the dash off to seal them though.
seuss79 is offline
post #7 of 8 Old 01-18-2013, 05:15 PM
seattle_yj
If you don't care too much about the looks,I use clear 100% silicone. Sometimes that rubber hose that exits the firewall on the passenger side will also clog with debris, you can pop it off and clean it out.
post #8 of 8 Old 02-02-2013, 01:47 PM
blakeg38135
the vent right behind ur hood has a drain tube if its stoped up that will happen. had it happen to me twice
blakeg38135 is offline
