Trans Tcase Breahter - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Trans Tcase Breahter
Ring & Pinion's, Lockers, 4340 Axles, Install Kits, BaWheeler Special! Black Steelies w/ 33" Mickey ThompsoROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 03-23-2015, 06:32 AM   #1
Ross
I have a 2001 5spd.
You can get a couple more inches from your Tcase and trans breather. If you look down from the driver side where the motor and trans meet you should see a breather. Carefully pull it out of the holder. Mine is rubber and came out easy. You should have a couple inches of extra hose you can pull up. I used zip ties to keep mine up and behind the engine.
I have a 2001 5spd. This the lowest breather on my jeep, it is now only about an inch or so lower than the breathers behind the gas cap. I didn’t tighten up the zip ties too tight so I could leave a little play.
If you want to spend more time and take it higher go here:
http://www.getahelmet.com/jeeps/tech/waterproof/
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor.
Ross is offline   Reply With Quote Quick reply to this message
