Trail Fix a Bent Tie Rod - JeepForum.com
post #1 of 3 Old 08-29-2004, 11:43 PM Thread Starter
MSHarnett
Broke Bogger
MSHarnett's Avatar
Hey guys, just thought I'd share a quick tip that I had to do that other day. I bent the crap out of my stock XJ tie rod will messing around on a few trails. There are 2 things you can try:
1. First is to loosen the bar and rotate it so the bend is going downwards. Use a bottle jack and try to jack it up. Lifting your driver side tire may help. This will get is close, but you'll still need to replace it. It'll get you home, which is the important part.
2. This is a good trick I though of in my sleep, like one of those I "see the light" moments. Use the handle from your hilift jack. You take off your tie rod and one end. Slide the a steel pole or a hi lift jack handle down the tie rod. If its gets stuck, the pick it up and slam it down on something hard, like a rock or something. Once its on, put the tie rod end back on and your in business.
In either case, you will mess up your alignment and your tie rod should be replaced as soon as possible. I was driving for like a month using a steel pole to hole the tie rod straight. I even wheeled with it. but it still held. I have since upgraded to a ZJ tie rod, which is much stronger then the junk hollow XJ rods. Hope this helps one of you some day
Matt
MSHarnett is offline
post #2 of 3 Old 08-30-2004, 03:24 PM
root
I had to do the Hi-Lift jack handle trick a few weekends ago to get home.
Worked well but I had ALOT of toe-out since we could not get the ends to thread back in far enough, but it got me home without a tow so I was happy.
The stocker is now replaced with a nice silver RE one, much easier to adjust now than the original.
Justin
root is offline
post #3 of 3 Old 09-14-2004, 09:08 PM
Rescue
Rescue's Avatar
Worked for me. In the middle of a mountain range!!
02 TJ Sport. RE 5.5 Extreme Duty LA. 2” spacers 1” body 1” MM. 38” TSL full width Dana 44 – 9” ARB front and rear. 4.0 - 5 speed. Warrior roof rack, euro guards, bushwhackers’, snorkel. Warn 8274.
Alaska Jeep Member #2
Rescue is offline
need to get some tube bent crazycollinz Fabrication Shop 5 09-10-2009 07:04 PM
bent Tie Rod Trail fix 1CleanTJ Cheap Tricks & Fixes 1 12-19-2007 09:56 PM
trail spares and trail fixes Mr.Crowley General Jeep & Off-Road Equipment 14 06-27-2007 05:37 PM
bent rims Super Jeep Tires & Wheels 4 01-27-2006 07:48 AM
Bent tie rod trail fix 97TJGUZZY Cheap Tricks & Fixes 2 03-14-2005 10:07 PM
