Tips for Better Gas Mileage.... - Page 4 - JeepForum.com
post #46 of 227 Old 03-05-2006, 06:53 PM
smartshot
Originally Posted by supr_bikr_99
Figure this had probably already been beatten to death as a topic, but what the heck! Just wanted everyone to share ways that they get better gas mileage in their rig. Mine has been not doing any unnecessary driving, LOL. What mods/tricks have you all used to get a few more miles per gallon?
you mean gallon's per mile , get a toyota... naw seriously keep your lead foot away from the gas petal. Get a air raid intake, exhaust.... then yes again stay away from the gas petal. I get about 21 on the highway. If i start to drive it like a bat outta hell then no less then 15 (this is offroad too).
smartshot is offline
post #47 of 227 Old 03-06-2006, 11:04 AM
79SilverCJ
Driving slowly to save fuel sounds good in theory while sitting at my computer reading this thread, but once I get behind the wheel with the top down on a sunny day, driving slow to save fuel doesn't really come to mind.
Oh well... it's a jeep, I didn't buy it for the gas mileage.
79SilverCJ is offline
post #48 of 227 Old 03-06-2006, 10:44 PM
Rocky5
Rocky5's Avatar
GOD I'M A SMARTA$$!!!!
better, but it only gets 30mpg ...my wifes 2006 Civic gets 33 city 38 Hwy
2006 Solar YELLOW UNLIMITED-6-Speed
-Rusty's 2" spring kit w/Skyjacker Hydro 7000 shocks, 1" coil spacers up front and 3/4" coil spacers in rear, 32" BFG AT KO's on Ravines
-Spidertrax 1.25" wheel spacers, Clear Turn Signals and Markers, Custom Front Bumper Hoop with upgraded hooks, Delta 50 Flowmaster, Code Alarm CA-670 Paging-Alarm with Motion Detector, K&N FIPK, JKS Discos, Procomp LCAs, Airaid TBS, Tuffy 055 rear section sub console, 4-Hella 500's, Fumoto Oil Drain Valve, Olympic Reverse-a-bars, Delta Headlight kit with black bezels, Edge Trail Jammer kit, Smittybilt Classic Tire Carrier, WARN Oil Skid, Skid Row steering skid, JKS adj. rear track bar, RC front adj. track bar.
Rocky5 is offline
post #49 of 227 Old 03-07-2006, 03:39 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
Jetta/golf/passat TDI w/ five speed, just under 50 mpg.
WALTER
walter_da_jpr is offline
post #50 of 227 Old 03-14-2006, 12:09 AM
Jeepmark
how bout a...
turbo charge it...easy and fasterrrrr
Jeepmark is offline
post #51 of 227 Old 03-15-2006, 07:27 PM
Josephrk24
I use my jeep alot for work in the winter... During every snow storm I get the WORST mileage.... As soon as I pull that lever back i start shoveling $$$ right into the gas tank... Im lucky if im getting like 9 MPG... thats driving all day, and all night, and somtimes most of the next day.... But thats ok.... I put it on the bosses account at the gas station
What can I do to get better mileage while in 4X4 ???
JOE
1990 YJ I6 258 AX-15 NP 231 *Now with Posi-Lok*
5 Inch BDS Lift
33X13.50 Mickey Thompson BaJa Claws
Early YJ club member #29
Josephrk24 is offline
post #52 of 227 Old 03-16-2006, 02:23 AM
Razor.
Razor.'s Avatar
Boring my TB helped, but only when I was light on the throttle. But who doesn't like to romp on it every so often right! I learned quick to not punch it, switching from a 240sx to a real machine!
Razor. is offline
post #53 of 227 Old 03-16-2006, 02:13 PM
walter_da_jpr
http://jeepforum.com/forum/showthread.php?t=229365
I'm telling you that this will work even in 4x4. You will have improvements.
WALTER
post #54 of 227 Old 03-17-2006, 11:16 AM
olljeepkidllo
"BTW - using the a/c will drop your mpg MORE than driving with a window down, so if the weather's nice, drop the window. If a new Civic looses around 6mpg with the a/c on, I'd hate to think what it does to us I thought this was crap, so I tested it in my xB with the a/c on and windows up - 244.7 miles to the 12 gallon tank. Window down, a/c off? 281.1 miles... Used the recommended gas-saving driving practices both times, too"
Actually mythbusters did that and the one with the ac on got significantly better MPG. Your car is ment to form a "bubble" to make it aerodymic, well as aerdynamic as a jeep can be, and once you open the windows you break the bubble causing more drag. =p Thought ya should know
olljeepkidllo is offline
post #55 of 227 Old 03-17-2006, 01:28 PM
walter_da_jpr
This does not occur in all vehicles. Windows all the way down in my Jeep gets 1-2 mpg less than a/c. This was also tested on Mythbusters in a truck. (Don't remeber which type). Smaller cars generally get better mileage with the windoes down.
WALTER
post #56 of 227 Old 03-18-2006, 06:18 PM
hikerpaddler
hikerpaddler's Avatar
That's the fact, jack. Reducing weight helps, but accelerating gently, coasting instead of accelerating to stop signs and redlights, and driving 65 instead of 80 will significantly reduce your mileage. Reducing weight can help, but not as much as care with the throttle. My problem is, I can really focus on mileage and achieve phenomenal results, but I go through phases where I just don't care.
Originally Posted by denverd0n
Drive gently. The plain fact of the matter is that there isn't anything you can do to your Jeep, or anything you can put in your gas, that will make even half as much difference to gas mileage as what you do with your right foot.
hikerpaddler is offline
post #57 of 227 Old 03-19-2006, 02:16 PM
wrangler35
i have a 94yj,run 35s, with 4.56 gears,4.0 ,flomaster, big bore tb. k&n filter, air aid tb. spacer. and i get 21mpg. and have more power than i did from factory.
wrangler35 is offline
post #58 of 227 Old 03-31-2006, 12:50 PM
pnpxtreme
Originally Posted by IU98
I don't know if these have worked yet-took of my hardtop, removed 33in spare, took out my back seat, put a k&n filter(I know the debate) and I stay out of the gas, people will not run over me they just pass and wave with only one finger. It beats hugging my buddy when he rides his moped.
Chad
LoL!
pnpxtreme is offline
post #59 of 227 Old 08-01-2006, 07:58 PM
DaleB
Thanks, Some really smart folks. I think I'll try taking my foot off the gas and only go downhill. '06 "X" highest mileage on the highway 13.7. Last two weeks in town and filled-up this morning 10.7. My second job is standing on the street corner with a bucket. Might be able to drive to work once a week rather than walking.
DaleB is offline
post #60 of 227 Old 08-02-2006, 01:07 PM
grymsr
Vintage Member
grymsr's Avatar
another MPG thread? AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARG!
How's that Hope and Change workin for ya?
Black Jeep Club v1.0 and v2.0 #1776
2004 Rubicon
2013 JKU Sport
grymsr is offline
bfg mt km mileage and tsl radial mileage epeck87 Tires & Wheels 1 03-29-2009 08:53 AM
Cd won't come out ! any tips? NCJEEPFAN Audio, CB & Ham Radios, GPS, & Electrical 2 03-04-2008 08:22 PM
CB Tips Idahomie Audio, CB & Ham Radios, GPS, & Electrical 15 11-14-2006 11:28 AM
Tips? mferrari General Jeep & Off-Road Equipment 1 01-15-2006 06:56 PM
Tips for a HD SYE? LOCKED UP Tires & Wheels 7 06-15-2003 06:21 PM
