Tips for Better Gas Mileage.... - Page 2 - JeepForum.com
post #16 of 227 Old 09-08-2005, 09:27 AM
beachtaco
beachtaco's Avatar
keep the top up, doors on and AC on. i get about a 1-2 mpg increase (from 12-13 mpg i get with my 4.0/5sp/35"/4.88 TJ). may not be much but every bit helps.
beachtaco is offline
post #17 of 227 Old 09-10-2005, 05:39 PM
supaasianpdjr
supaasianpdjr is offline
post #18 of 227 Old 09-12-2005, 04:40 PM
bono426
bono426's Avatar
dude, whats the point of having a jeep then? for 2mpg i would rather have fun with the top and doors off.
(but i also dont have ac)
1998 ZJ (What in the heck is a ZJ?)
5.2 V8
bono426 is offline
post #19 of 227 Old 09-23-2005, 05:37 PM
nitecop
My 99 4.0 5spd 3.73 gear 30 inch tire gets a even 20mpg. Took the hard top and doors off and it dropped to 19.1 go figure. Its all stock fresh tune up, 85k miles, i shift between 2kand 2.6k rpm.
I think I have a small crack in my exh manifold cause it feels like I have a slight lean surge at part throttle accelation. I just got a new manifold just and haven't got the time to put it on. If the milege drops when it is installed then ill know what it was.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #20 of 227 Old 09-29-2005, 12:11 AM
Koz83
So does a cone filter/intake (such as what xj-armor.com sells), high-flow cat-back (Flowmaster, lets say), splitfires and a better ignition actually help, or are they more of a plecebo effect with our 4L ho's?
I've been scratching my head with respect to putting in some or all of these mods but I wonder whether or not its worth it. I mean I'd rather not spend the money to gain a few horses but end up using just as much fuel.
98 XJ, 4L
Koz83 is offline
post #21 of 227 Old 09-29-2005, 08:38 AM
denverd0n
All these things will help a little. The problem is that they are expensive enough that the payback period is going to be measured in tens of thousands of miles.
denverd0n is offline
post #22 of 227 Old 09-30-2005, 01:50 PM
beachtaco
beachtaco's Avatar
i agree... warm weather the top is down but cold weather the top goes up...
post #23 of 227 Old 09-30-2005, 03:00 PM
DigDug
Check out this article:
http://cnn.edmunds.com/ownership/dri...2/article.html
... an informal test on some of the common fuel savings tips.
Check test #3... Take it easy on the gas pedal (like mentioned earlier)...
I tried it and my average mileage for that tank went up over 20% (I don't remember the exact numbers, just the final results).
Here's the funny thing--- It didn't take any longer to get where I was going! Most of the time, I'd get the "one finger wave" from the tailgaters as they passed me, but I got to chuck a cheezy "I'm getting 20% better gas mileage and getting there just as quick as you" grin as I pulled up next to them and waited at the next red light...
Think about it this way: They were behind you at one light, they speed to the next one and now their 2 cars ahead of you, that's a 3 car jump... We all follow the car ahead of us by 2 seconds (yeah right - but let's assume)... He burned 20% more gas to save 6 seconds? Not worth it to me!!! Lots of times, I'd even be ahead of them at the next light because of lane choice...
Keep the foot off the skinny pedal, your engine and your wallet will appreciate it... With a 15 gallon tank in my TJ, it was also nice to get an extra 40-50 miles out of that tank...
DigDug is offline
post #24 of 227 Old 10-16-2005, 11:16 PM
NMPhi767
You could buy a 15 year old Honda Civic for like 600 bucks and only use the Jeep for fun stuff.
I know, crappy suggestion, but with gas at 3 bucks plus, what do you want?
NMPhi767 is offline
post #25 of 227 Old 10-17-2005, 06:54 AM
'88 Cherokee
I got a whopping 117.3 miles to my ENTIRE tank, in three days. City driving, under 2500rpm, light accelerating and coasting as soon as the light turns red (a/c off, weather's nice why use it?) and never once exceeded 50mph... WTH is wrong?!
BTW - using the a/c will drop your mpg MORE than driving with a window down, so if the weather's nice, drop the window. If a new Civic looses around 6mpg with the a/c on, I'd hate to think what it does to us I thought this was crap, so I tested it in my xB with the a/c on and windows up - 244.7 miles to the 12 gallon tank. Window down, a/c off? 281.1 miles... Used the recommended gas-saving driving practices both times, too
'88 Cherokee is offline
post #26 of 227 Old 10-17-2005, 01:15 PM
sports2259
Better gas mileage
Two things I have found to increase my gas mileage was to throw on a cold air intake and a performance exhaust. My TJ went from 200 miles per tank to around 250-275....Also having a lead foot doesn't help
sports2259 is offline
post #27 of 227 Old 10-17-2005, 05:54 PM
FlaJeepin
A cold air intake accually dropped my gas milage by 1.5 mpg. I guess every Jeep is different.
One thing I have noticed is when I put the top down I tend to get heavy with the right foot. I don't know why. Top down I have to go faster.
FlaJeepin is offline
post #28 of 227 Old 10-18-2005, 07:13 PM
'88 Cherokee
I end up going faster with the windows down because I like the sound of the exhaust and the tire howl... Also, if you're in a fuel-conservative mood listen to more mellow music... studies have actually proven that faster music (metallica and similar bands) causes drivers to grow lead feet
post #29 of 227 Old 10-18-2005, 07:41 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
IIRC several jeep engineers have gone on to state that the stock intake is nonrestrictive, meaning there is more CFM that can flow through the stock setup than can be used at WOT.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #30 of 227 Old 10-18-2005, 08:05 PM
subaruboy
Originally Posted by paultyler
But I bet you have stock tires, right? I have 33s and 20 mpg is only a dream. I get 12. Maybe 13 if I am lucky.
you have a lot of addedweight in mods... did you regear for those bigger tires? if not i bet you would get better mileage if/when you do.
at highway speeds i think i get best mileage using the vent and keeping the windows up... the blower motor doesn't put hardly any load on the engine, and having the windows closed keeps what little aerodynamics it has. i think even if i ran my A/C, i would stil get better mileage than if i opened the windows. too much wind resistance. also i only do 65 or below, and i shift at 2000-2200 rpms
around town, aerodynamics don't matter as much because of low speeds... so window open tends to be the best.
i consistently get 21.3 mpg
00 Jeep TJ SE Amberfire Pearl- Sold :'(
87 Yota Pickup
05 PBM M6 GTO
07 Ford Focus
subaruboy is offline
bfg mt km mileage and tsl radial mileage epeck87 Tires & Wheels 1 03-29-2009 08:53 AM
Cd won't come out ! any tips? NCJEEPFAN Audio, CB & Ham Radios, GPS, & Electrical 2 03-04-2008 08:22 PM
CB Tips Idahomie Audio, CB & Ham Radios, GPS, & Electrical 15 11-14-2006 11:28 AM
Tips? mferrari General Jeep & Off-Road Equipment 1 01-15-2006 06:56 PM
Tips for a HD SYE? LOCKED UP Tires & Wheels 7 06-15-2003 06:21 PM
