Tips for Better Gas Mileage.... - Page 11 - JeepForum.com
post #151 of 227 Old 06-15-2009, 01:33 PM
bjones71087
the money we spend on gas for our jeeps is a lot less than we would spend to keep up with parts and problems of a rice burner though....im just sayin.
bjones71087 is offline
post #152 of 227 Old 06-15-2009, 02:20 PM
Shiguy
LJ Trek Top?
I'm reposting this since it was the last comment on the previous page in hopes somone will see it.
Just out of curiosity has anyone here with an LJ tried the "Trek Top" by Best Top? The reason I ask is that this has a slanted backside for the jeep and the LJ's in particular have the most sloped backend. I've been thinking of getting one because i like the look and from an aerodynamic perspective they should create a fairly noticable difference when doing highway driving. The regular TJ's and X's probably wouldn't notice as much as the slope of the rear is not as gradual as it is on the LJ's.
Shiguy is offline
post #153 of 227 Old 09-07-2009, 09:52 PM
Boobah
Originally Posted by beachtaco View Post
i agree... warm weather the top is down but cold weather the top goes up...
Hahahaha, I like the heat and never used AC until I moved to TX..... Jul-Aug AC is almost a necessity
If you don't change your today, your tomorrow will be the same as yesterday. Make the commitment to change your life forever!
Boobah is offline
post #154 of 227 Old 09-07-2009, 11:01 PM
Boobah
Ok so it really boils down to... is that is depends on the car.... I had a 95 BMW 525i that got 33-35 on hwy...avg 26-28, put a K&N lost Gas mileage and power.... had a 94 ZJ with 4.0 auto, avg 22-24, and is faster then my 00 TJ 4.0 manual...as far as get up and go.. TJ avg 14-15 and it's stock... however I did notice that at 80+ the gas mileage dropped a lot even with a egg under the pedal. I do believe I need a tune up and hope that helps not only mileage but power as well.... hubby says I need a cold intake, performance chip and something to do with my exhuast... and that will help with power which will help with mileage.
Boobah is offline
post #155 of 227 Old 09-08-2009, 12:52 AM
01CHEEKEE
easiest way to improve gas mileage is lighten and lift your FOOT!!!
don't tromp it from lights, and slow down on the highways...
01CHEEKEE is offline
post #156 of 227 Old 09-08-2009, 02:00 AM
karlo
Lighten your load by removing those unnecessary stuff and tools. Also, don't accelerate so hard.
karlo is offline
post #157 of 227 Old 09-13-2009, 10:13 PM
loneeagle78
1990 XJ Cherokee
Originally Posted by armymedicsfc View Post
Not sure I understand "Nitrogen" in the tires. Isn't air already 78% nitrogen?
since no one is answering on the nitrogen........ with nitrogen, the molecules dont expand and contract like shop air in the tires, therefore keeping fairly close to the same pressure all the time in your tires. with shop air in the tires, the pressure has been known to increase up to and above 5 psi. hope this helps you armymedic.
I am runnin my XJ with 4 1/2 lift, 32 at tires at 25 psi, 4:10 gears, and an auto. I consistently get 15 in town and around 18 on highway.
with the ZJ, all stock with 235 on it, I get 20 at 80, and usually get around 18 in town. used to have a mitsu galant that got 30-35, but I hated getting stuck in the driveway all the time in winter. MPG's arent worth it if you cant go anywhere!!!
JEEP.......not just a vehicle.........its a lifestyle!!
loneeagle78 is offline
post #158 of 227 Old 09-14-2009, 10:34 AM
EvilM0nkey
EvilM0nkey's Avatar
It's also nearly imposable to get 100% nitrogen in your tires.
EvilM0nkey is offline
post #159 of 227 Old 09-26-2009, 11:16 PM
CRWDDYZ
CRWDDYZ's Avatar
I did not buy my Jeep for gas mileage, thats for sure...this is what I do.
When the tank is empty, I refill
2006 Rubicon Purchased new on 9-26-06. Paid off 9-26-09. Time to build now. First Jeep and I dig my rig !
CRWDDYZ is offline
post #160 of 227 Old 09-27-2009, 05:07 AM
rpiereck
This is the best known mod to improve your gas mileage, 100% guaranteed. Get one of these and you will see an excellent fuel mileage on your work commute: http://tiny.cc/wNCTS
JKS Adjustable control arms - JKS 1.25" Body Lift - JKS 1" Engine Mount Lift
Old Man Emu 4" coils - Rancho 5000 shocks - Teraflex front adj trackbar - RE rear track bar bracket
33/12.5x15 Wrangler Duratracs - Tabor 12k Winch - Hella 500F Foglights
Hella Supertone Horns - Uniden CB radio
rpiereck is offline
post #161 of 227 Old 09-28-2009, 10:03 PM
rivalarrival
Stormaggedon
rivalarrival's Avatar
Install a vacuum gauge. Old-school, barometric models use a piece of vacuum line connected as close as possible to the intake manifold. (I usually just tee it into an existing line.) They can be had for under $20. Newer electronic models use a sensor/sending unit to control the gauge. I can't vouch for them, I've only ever used the barometric models.
To use it, pick a number on that gauge, and don't let it go below. In general, the higher the number, the higher your MPG. It's amazing to see how much that gauge wants to drop just to get rolling, and how long it wants to stay down there while you accelerate.
I saw 2-4mpg gains in my old S10 just by slightly altering my driving style. Haven't added this gauge to my jeep - I've only had it about a month and we're still just getting to know eachother.
rivalarrival is offline
post #162 of 227 Old 09-28-2009, 10:26 PM
mightydog78
our air is made up of a majority of nitrogen. the whole 100% thing is stupid.
(someone may have already said this..)
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #163 of 227 Old 09-30-2009, 04:36 PM
BlackedOut13
As my friends and I always say when someone asks why you get bad gas mileage...because its a Jeep (its one of those things we do understand haha)
BlackedOut13 is offline
post #164 of 227 Old 10-03-2009, 03:54 PM
emoney
Many people will say that accelerating slowly is a good way to get better mpg, but that actually isn't the case. What works the best is to accelerate quickly into second gear, the slowly build up speed from there. Cars are least efficient when they are running at really low RPM, low speed, and low torque. You need to spend as little time as possible around the lowest end of the spectrum. When you're at 0 mph, all the gas being used just keeps the engine running, and it's not used to overcome external forces (friction, weigh, air resistance, etc...) at 5 miles per hour, the jeep is running at very low rpm, and most of the gas is used just to keep the engine from dying. Once you hit 10-15 mph, you're primarily overcoming the normal force between your car and the road, and almost no gas is used solely for the purpose of keeping the engine running, that's when you should stop accelerating as rapidly and let the car slowly gain speed up to the cruising speed.
emoney is offline
post #165 of 227 Old 10-08-2009, 06:08 PM
rivalarrival
Stormaggedon
What about Jeeps?
bfg mt km mileage and tsl radial mileage epeck87 Tires & Wheels 1 03-29-2009 09:53 AM
Cd won't come out ! any tips? NCJEEPFAN Audio, CB & Ham Radios, GPS, & Electrical 2 03-04-2008 09:22 PM
CB Tips Idahomie Audio, CB & Ham Radios, GPS, & Electrical 15 11-14-2006 12:28 PM
Tips? mferrari General Jeep & Off-Road Equipment 1 01-15-2006 07:56 PM
Tips for a HD SYE? LOCKED UP Tires & Wheels 7 06-15-2003 07:21 PM
