Quantcast Tic-Tac LED Third Brake Light... Again!! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > Tic-Tac LED Third Brake Light... Again!!
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 01-28-2009, 04:46 PM   #1
stunner
So... I got a PM from another forum member asking me if I would build him a Tic-Tac LED brake light like the one I built for myself HERE.
I really didn't feel like working today so...
Here are some progress pics:
[COLOR="Navy"]2005 Patriot Blue Rocky Mountain Edition Wrangler
OME HD ZJ/LJ Combo Lift, OME Long-Travel Nitrocharger shocks, AA SYE + CV DS, Nth Degree Mobility TT, JKS Adj. Rear UCAs, JKS Adj. Front & Rear LCAs, JKS Adj. Front & Rear Trackbars, JKS 'Quicker' Discos, 33x10.5 KM2s on Stock Ravines, Warn Front and Rear Bumpers, Bestop Tinted Window Kit.[/COLOR]
[SIZE="4"][B][COLOR="navy"][URL="http://www.jeepforum.com/forum/showthread.php?p=5322408#post5322408"][SIZE="3"][COLOR="Navy"]See My Build-Up Here[/COLOR][/SIZE][/URL][/COLOR][/B][/SIZE]
[COLOR="Navy"]My other posts:[/COLOR]
[COLOR="navy"][URL="http://www.jeepforum.com/forum/showthread.php?t=569601"][COLOR="Navy"]Foglight Switch Operation & Pin-Out[/COLOR][/URL][/COLOR]
[URL="http://www.jeepforum.com/forum/showthread.php?t=579055"][COLOR="Navy"]OME HD Coils - Let's End the Confusion!![/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/showthread.php?t=571323"][COLOR="Navy"]JK 'style' bumpers for TJ? Do they even exist?[/COLOR][/URL]
[COLOR="Navy"][URL="http://www.jeepforum.com/forum/showthread.php?t=588694"][COLOR="Red"]Caster? Pulling to right after lift...[/COLOR][/URL][/COLOR]
[COLOR="Navy"][URL="http://www.jeepforum.com/forum/showthread.php?p=5664193&posted=1#post5664193"][COLOR="Navy"]LED Third Brake Light made out of a Tic-Tacs Box[/COLOR][/URL][/COLOR]
[SIZE="2"][COLOR="Navy"][B]Blue Jeep Club Member #279[/B][/COLOR][/SIZE]
stunner is offline   Reply With Quote
Old 01-28-2009, 04:47 PM   #2
stunner
Some more progress pics:
Old 01-28-2009, 04:48 PM   #3
stunner
A few more:
Old 01-28-2009, 05:15 PM   #4
stunner
Finished!!
Old 01-28-2009, 08:41 PM   #5
berettajeep
Very nice! I think I will "borrow" this design for some rock lights.
'02 Liberty
'47 CJ2A My CJ2A build
'47 CJ2A truck build my-cj2a-truck-build-lots-pictures
berettajeep is offline   Reply With Quote
Old 01-29-2009, 09:10 AM   #6
SinCityCJ
Very cool. Gave me a few ideas for some places I need some lighting. What ohms were the resistors you used?
www.militaryjeepers.com
SinCityCJ is offline   Reply With Quote
Old 01-29-2009, 10:57 AM   #7
stunner
The LEDs were 2.4V @ 20ma so, to run on a 12V-14V system I needed 240-270 Ohms. I used two 120 Ohms resistors in series to achieve 240 Ohms!
Old 01-29-2009, 07:55 PM   #8
mark02tj
OK, DUMB question from a non-electronics person. How did you know that you needed 240-270 Ohms? I'm sure there's some sort of formula to knock 12V down to 2.4V but I'd have no idea even where to look for something like that.
THANKS!!
mark02tj is offline   Reply With Quote
Old 01-29-2009, 08:43 PM   #9
stunner
THANKS!!
Dude, the only DUMB questions are the ones never asked!!
Actually, if you wire the LEDs in series it looks something more like this:
2.4V + 2.4V + 2.4V = 7.2V (Because I used 3 LEDs)
So, you need to bring the 12V down to 7.2V.
The formula is: R = (VS - VL) / I
R = Resistor
VS = Supply Voltage
VL = LED Voltage
I = LED mA (or current)
So for what I did:
[12V - (2.4V + 2.4V + 2.4V)] / 20mA = .24 or 240 Ohms
It's 240 and not .24 because it's 20mA (which is miliAmps so, you move the decimal over by 3).
Hope this helps!!
Old 01-30-2009, 04:56 AM   #10
mark02tj
Hope this helps!!
Helps a lot!! THANKS!!
So if you would have used 5 of the LEDs, you wouldn't have needed any resistors (5 x 2.4v = 12v) ?
It's been since high school (almost 30 years) since I've had an electronics course so I could use a refresher.
Next dumb question - can you "dim" LED's like you can dim an incandescent bulb? I'm guessing "yes" since there are the LED taillights with brakelights. Or, do those have two sets of LEDs in them - one for the taillights and one set for the brakelights?
If you wired a pot into the circuit, would that act as a "dimmer" on the LEDs?
Oh, Mr. Lowmiller (my HS electronics teacher) is spinning in his grave!!
THANKS again for your help!!
Old 01-31-2009, 12:30 AM   #11
stunner
Howdy!!
You can definitely dim LEDs... you'll need a low voltage dimmer (essentially a pot). You can get one at radio shack or take one off a car from the junkyard (those work too!).
I've never tried the potentiometer approach but, I'm sure it would work. I would get one that would let you turn it to full voltage (12v) as opposed to the more precise ones like a 1k... I guess it depends on your application.
Have fun!
Old 01-31-2009, 12:13 PM   #12
JaikYJ
1987 YJ Wrangler
Those look really good, thats a great home made mod!!
Cheers for sharing.
JaikYJ is offline   Reply With Quote
Old 02-08-2009, 09:47 AM   #13
green_jeep
Cant wait to mount it up on my jeep!!!!!!!!
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
Jeep, Bike, and Street Rod, i NEED MORE money
green_jeep is offline   Reply With Quote
Old 02-18-2009, 10:17 PM   #14
green_jeep
got it mounted up on my jeep but mounted it a lil different then u did Stunner.
i took my plastic center cap off my spare tire cut a hole in it for the tic tac box to fit into then used silicone to make it stay there nice and tight.ran the wires with a plug (so if i have a flat i can take it off put it in the glove box).
painted the centercap flat black so you can hardly see it when its not lit. no pics yet but i'll snap a few tomorrow when i have someone to hit the brakes, and daylight so you can see it in the day.
Thanks again real nice lil light!!!!!!!
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
Old 02-18-2009, 10:33 PM   #15
green_jeep
ok couldnt wait 2X4 block of would on the pedal and a mini mag light works LOL
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
Glock Forum
