Stuck doors - JeepForum.com
post #1 of 3 Old 07-05-2013, 08:32 PM Thread Starter
caiha
Stuck doors
The rear doors on my wrangler are tough to get off. I finally took the hinges off with the door and took a rubber mallet to the hinges to break them loose. I put brake caliper lube inside the hinges and worked the door into them but had no luck. The doors are still getting stuck. Thoughts??
caiha is offline
post #2 of 3 Old 07-09-2013, 07:56 PM
TheBoss
Try getting some new delrin bushings. Were they corroded at all?
TheBoss is offline
post #3 of 3 Old 07-09-2013, 08:42 PM Thread Starter
caiha
You are talking about the thin piece if material that sits inside the hinge, yea corroded. Is there a replacement bushing that is better material and where do I get these bushings.
caiha is offline
