Soft Window Repair!! - JeepForum.com
post #1 of 5 Old 05-31-2015, 08:15 PM Thread Starter
LostInMI
So I trolled the internet as usual, seeking low cost effective repairs for soft top/door windows..
I purchased a pair of beautiful OEM door uppers for my YJ for $40.. One however had the notorious tape over crack/cut/rip, no idea what caused it as I purchased them this way..
Finding nothing that satisfied what I wanted, while cleaning my shed I seen my daughters catfish pole, with 25# braided line and it all came together..
First I tried Goof off to clean all the tape residue off, got most off but the balance just would not come off, so instead of potentially scratching or damaging them further, I figured mother nature will remove it in due time.
I stitched it loosely with a heavy needle and the 25# braided line, and used crochet needles to gently/gradually tighten the stitches as I went. When I say gently/gradually, I mean gently and gradually! Too much force or too tight too fast could make the damage even worse.
By the time I got all the stitches in, I went through them about 5 times slowly tightening them, I managed to essentially close the damaged area near perfectly.
I applied LocTite 2 in 1 Tub & Tile adhesive sealant. It has indoor/outdoor rating and pliable.
The end result I was honestly pleased with, it is nearly perfectly clear, the stitches are hardly noticeable, and I anticipate it holding up to weather and abuse with no issues!
So if anyone has the patience, this turned out quite beautifully without having to replace gaudy tape or look at tape!
LostInMI is offline
post #2 of 5 Old 06-04-2015, 02:05 PM
Ross
good job, looks good
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #3 of 5 Old 06-05-2015, 01:17 PM
99TJ5SP
Second that... nice and simple
99TJ5SP is offline
post #4 of 5 Old 06-05-2015, 03:34 PM
MRknowitall666
RIP Wounded Warrior
1950 M-38
I just had to repair my soft top window several days ago. My fix was not as nice as yours. I wish I had tried yours now.
DAV Wounded warrior project
MRknowitall666 is offline
post #5 of 5 Old 09-15-2015, 09:57 PM Thread Starter
LostInMI
Next time!! It has held up no issues so far (other than dumb neighbor kid trying to peel off the silicone)..
LostInMI is offline
