soft top repair? - JeepForum.com
post #1 of 15 Old 04-01-2012, 09:13 PM Thread Starter
carpediem51083
soft top repair?
i just noticed tonight that i have a small tear starting in the top of my soft top!!! we being as i cant afford a new one right now is there any way of patching it? thanks in advance
carpediem51083 is offline
post #2 of 15 Old 04-03-2012, 02:05 PM
Robinn
how large is the rip? if it's small and unnoticable you could try to use duct tape from the inside to hold you over... my soft top is from '09 so i havent had any problems yet, so dont hate my duct tape idea!
Robinn is offline
post #3 of 15 Old 04-03-2012, 05:56 PM
Wrangler_91
I have heard if people sewing it back together and using some sealent to seal it back up. I have a big rip in my top and plan on doing this.
Also i know you can take it to a boat shop that works with canvas and they will repair it fairly inexpensively
Wrangler_91 is offline
post #4 of 15 Old 04-03-2012, 11:04 PM
dangurney75
If you want to do it yourself, I have seen repair kits for sale and even heard of people using convertable repair kits.
dangurney75 is offline
post #5 of 15 Old 04-04-2012, 10:01 AM
Ross
I got these iron patches a few weeks back and they worked great. Easy to easy and so far so good. Somewhere on this site is a write up for them.
http://www.amazon.com/gp/product/B002762VH0/ref=oh_o02_s00_i00_details
Iron-On Heavy Canvas Patches 5x5 2-Pack: Black
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #6 of 15 Old 04-04-2012, 10:03 AM
AmbuGrl
AmbuGrl's Avatar
take it to a local boatshop. they can sew a patch over it for super cheap.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #7 of 15 Old 04-05-2012, 07:52 AM
Tessellate
Go into any camping store and buy a "Tent repair kit" Ensure its for a canvas tent. It comes with everything you need and more all for under a 5$ bill.
Tessellate is offline
post #8 of 15 Old 04-05-2012, 08:39 PM
sikencide
liquid rubber works well on small holes too.. dryes clear most times and stays flexible.. ooor iron on patches.
123456789
sikencide is offline
post #9 of 15 Old 04-10-2012, 09:30 AM
Jmaster5
I had a soft top rip on my last Jeep TJ (97) and I took it to a marine store Charleston SC- big one sold repaired boats. They have these giant sewing machines to make canvas to cover expensive boats. They repaired my top hella cheap (80 dollars) and it was stronger and better than the stitching on the rest of my top. Granted that was 10 years ago but you can give it a shot. They took it off the frame and replaced it as well. To them it was no big deal it seemed and it was almost too small of a job but they did it with a smile.
Good luck.
John
Jmaster5 is offline
post #10 of 15 Old 04-10-2012, 12:48 PM
grisgris
Stitch across the rip using a sewing awl then clear or black Shoe Goo over the top.
grisgris is offline
post #11 of 15 Old 04-22-2012, 08:18 PM
Mannyssj13
second the boat shop
Mannyssj13 is offline
post #12 of 15 Old 05-03-2012, 09:09 AM
echowhisky
3rd the boat shop
echowhisky is offline
post #13 of 15 Old 07-30-2013, 09:57 PM
aqdned
2000 YJ Wrangler
Top repairs
I found two options for quick fairly rugged repairs:
1- For small tears Gorilla glue applied to a cut piece of rubber (innertube, gasket blank). Clean the tear, smear GG onto the underside of the top and the rubber, hold down from above the top and from under on the rubber for five minutes or so, done. Watch out for excess on your hands, or you'll be part of the patch. I've used GG for wetsuit repair and it was good up to four inch slices, still working. Top repair is 2 months in, still dry.
2- For plastic inserts above doors, at tub rails, and for all canvas seams the solution so far is from Michaels. I asked for heavy duty needles (explained the issue) and the sales person recommended sinew. I pulled enough sinew through large needle (about 30") to sew with. Then, knotted the end, and pushed the needle through first section of plastic (carefully, best to find an existing hole otherwise they break), and went around the outside edge and repeat equally spaced threading. At end loop and pull a knot tight to tie it off. One frayed and I applied a drop of GG to lock it in.
Hope this helps...
aqdned is offline
post #14 of 15 Old 07-31-2013, 01:38 PM
Wrangler_91
I had a large tear in mine. I got a patch and sewed in in on the inside and put some silicon on it. Still holding up more than a year later.
post #15 of 15 Old 12-11-2014, 06:44 PM
craftg
Step by step instructions and a new repair kit from McNett: https://www.mcnett.com/blog/jeep-soft-top-repairs
craftg is offline
Soft top repair danj General Jeep & Off-Road Equipment 6 11-12-2011 10:28 PM
Need to repair hole in Bestop soft top! mcdcrook General Jeep & Off-Road Equipment 3 11-10-2009 10:21 AM
soft top window repair mfinn General Jeep & Off-Road Equipment 5 05-18-2008 11:27 AM
Beyond repair? The Von General Jeep & Off-Road Equipment 1 03-29-2008 03:02 PM
Black soft 8's or Silver soft 8's? CHRRRIS Tires & Wheels 3 02-22-2008 08:42 PM
