shift knob - JeepForum.com
post #1 of 5 Old 12-25-2005, 04:38 PM Thread Starter
highroller84
shift knob
how do you get the shift knob off of a stock shifter on a 2000 wrangler? any help much appriciated!!
highroller84 is offline
post #2 of 5 Old 12-25-2005, 04:57 PM
C2U5H
C2U5H's Avatar
stick a knife into the edge of the cap (where the shift pattern is printed on) and pop it off (it's a biatch to get off). there's a bolt under the cap...don't remember what size. undo the bolt on it should come off.
~J
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #3 of 5 Old 01-03-2006, 09:22 PM
CptTrips
Yup. The cap pops off (mine is pretty easy), and simply unbolts.
CptTrips is offline
post #4 of 5 Old 01-04-2006, 09:48 AM
denverd0n
Simple trick to make taking it off easier... Heat up the knob first with a hair dryer. This will slightly soften the plastic (or whatever it is) and make popping the center out just a little bit easier.
denverd0n is offline
post #5 of 5 Old 01-04-2006, 10:40 AM
nedder
The nut is a 15mm
Fly far, fast, and furious!!!
nedder is offline
Badass Shift Knob bokey Cheap Tricks & Fixes 301 09-30-2013 10:14 PM
Home-made wooden shift knob flatlander757 Fabrication Shop 31 01-15-2010 11:13 AM
Aftermarket Shift Knob CherokeeClassic Street Jeep Forum 3 08-15-2007 08:54 PM
transfer case shift lever hard to shift phant0omx Engines & Drivetrain 1 08-18-2006 07:59 PM
Shift Knob RoverJeep90 Cheap Tricks & Fixes 10 04-20-2006 10:54 AM
