Shaking sound when stopped in drive - JeepForum.com
post #1 of 10 Old 11-30-2013, 06:33 AM Thread Starter
sparnell1994
Whatsup guys I have a 95 jeep grand cherokee Laredo when I put it into drive or reverse with my foot on the brakes it shakes and makes areally annoying sound Kindve like something is loose but as soon as i accelerate it stops any ideas?
sparnell1994 is offline
post #2 of 10 Old 12-01-2013, 01:11 AM
AF-Jeff
1979 FSJ Cherokee
My buddies trans am does the same thing. Every time he is at a red light his dash shakes all over the place but stops as soon as he gets to moving.
AF-Jeff is offline
post #3 of 10 Old 12-02-2013, 09:48 AM
d_diesel27
I have the same problem, my clutch just got replaced the other day and this noise came with it. I would also like to know what this is. Mine sounds like its coming from the right part of the dash. I looked for what it could be and found nothing
d_diesel27 is offline
post #4 of 10 Old 12-02-2013, 03:47 PM Thread Starter
sparnell1994
I have an automatic sadly I'm gonna do a tune up Saturday morning on it hopefully it will help do you think maybe it could be something loose in the dash
post #5 of 10 Old 12-02-2013, 04:01 PM
d_diesel27
Thats what i hope, just something not so important knocked loose
post #6 of 10 Old 12-02-2013, 07:44 PM
Jimbo58
I would check the tranny mount. I had a vehicle the shook like describe and it turned out to be the tranny mount. Just my 2 cents.
Jim
Jimbo58 is offline
post #7 of 10 Old 01-18-2014, 05:34 PM
CrowDriver
Could this be a u-joint that stops vibrating when the rpm goes up, sort of dynamically balanced but not at low revolutions? Happened to me long ago, but can't remember if the noise went away at high or low rpm, was one or the other.
CrowDriver is offline
post #8 of 10 Old 01-19-2014, 08:50 AM
Indy
Indy's Avatar
Ujoints dont turn when the car isnt moving.
I'm the only gay eskimo.
Indy is offline
post #9 of 10 Old 01-21-2014, 03:05 AM
CrowDriver
I am sure that is news to us all, so thanks.
post #10 of 10 Old 01-21-2014, 12:19 PM
longman
2014 JK Wrangler
On my old XJ, the exhaust pipe runs VERY close over the top of the trans/xfer case crossmember. If the engine is running the least-bit rough, it shakes a bit ...enough to cause the pipe to make slight contact with the crossmember, causing a "shaking sound" very much like the OP describes. You can't really pinpoint where it's coming from when inside the Jeep, because it resonates through the whole bottom side.
After the engine got about 175k miles on it, no matter how much I tried to smooth the idle out with a tune-up, it would still do it sometimes (i.e. cold mornings, etc.). I finally jacked it up and gained enough clearance by reefing on the pipe with a large bar.
Just something cheap to check (clearances of exhaust pipe to frame members etc.)
longman is offline
