Rusted YJ Fender Hole Fix - JeepForum.com
post #1 of 24 Old 11-13-2010, 08:57 PM Thread Starter
johnrmclean
I have a 94 YJ. Most of the fender is good except for a rusted through hole above the wheel well in the typical place. Does anyone have a cheap fix/cover idea to salvage the the fender withour having to replace it??
johnrmclean is offline
post #2 of 24 Old 11-14-2010, 06:45 PM
GilNewJeeper
2008 KK Liberty
This is how my friend saved my passenger fender; if you know how to weld you can do it yourself, I don't have the skills yet.
Rusted Spot
Step 1 - cutting the rusted part
Step 2 - Sanded and prepared
Step 3 - Cut a piece to weld on
Step 4 - Weld the new piece
Step 5 - Do the body work
Last step - prime and paint
Hope this can help
Did you Hug your Jeep today?
2008 Jeep Liberty
1994 Wrangler Sahara
GilNewJeeper is offline
post #3 of 24 Old 11-14-2010, 08:09 PM
MattTB
It probably would be cheaper and faster to find someone parting out their jeep locally and buy theres.
MattTB is offline
post #4 of 24 Old 11-15-2010, 01:16 PM
biggoofy
thats not cheap unless you spray paint it after lol
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #5 of 24 Old 11-16-2010, 07:27 PM
jeepdavetj
1991 XJ Cherokee
A sticker.
I don't blame people for their mistakes, but I do expect they pay for them.
Ash from Army of Darkness
Alright you Primitive Screwheads, listen up! You see this? This... is my boomstick! The twelve-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about a hundred and nine, ninety five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You got that?
jeepdavetj is offline
post #6 of 24 Old 11-19-2010, 03:54 AM
SRC21
If you want super cheap and don't mind a rough look (that is if you don't apply body filler afterwards and paint)
you can use fiberglass. Its not correct but will work.
Or you can put cardboard behind it and bondo on top like the monkey that owned my jeep before me did! Seriously don't use cardboard.
SRC21 is offline
post #7 of 24 Old 11-19-2010, 11:38 AM
idolax
Its the Thrill of Victory, to do it yourself.
Lifted with tires and some rust, it runs, I fix, it runs, I fix, and I have fun.
Never rush to buy a jeep, save cash to fix it!
idolax is offline
post #8 of 24 Old 12-13-2010, 06:30 AM Thread Starter
johnrmclean
Sweet repair done right......I did one Jeep that way too. Last one I just replaced the whole fender. I had the exact same rust situation on this Jeep(among others) I have a welder but suck welding sheet metal. I tried something new .......glue...... worked great... I actually made a replacement piece out of heat duct sheet metal including a flange on the back side to reattach the fender flares then I used construction adhesive to attachesd it but rather that feather the piece into the rest of the body with bondo....since I also had other rust spots along the rocker panels....On the sides I cut the worst rust out and treated the remainder with with encasulator. I screwed, pop riveted "nd or glued some pieces of heat duct sheet metal over the holes and then bought 2 pieces of flat metal 62" x 6" primed and painted it black then glued ( construction glue and a caulk gun) and screwed it along the whole rocker panel from wheel well to wheel well. Looks great. Inside I cut the rust holes out, encapsulated the rust and replaced the floor pans with new ones from Quadratec. They have new pans now that are a few buck more than the old flat replacement but are a direct replacement and are already e coated. They fit great and are well worth the extra $30!!!!!!!!!!!!! Again I used glue and screws to install the new pans. Then I rebuilt the inner walls of the tub/rocker panels by using glued in metal covered with high fiberglass content fillers, fiberglass dry wall mess tape and fiberglass mesh fabric. It worked out really well. By extensively using construction glue I avoided having to do any welding and have a water tight permanent repair. Fairly easy and sweet. On the top side of the fender I made a U shaped panel out of diamond plate wheel flaps to cover over the rusted and cracked fender and create support to srew the wheel flare back into. Worker great, cheap and looks like an accessory. I may put a hook or something on it to make it look even more functional. Bad thing about Jeeps is they are rust buckets..good thing is a creatrive person can find a lot of ways to repair them cheap.... a couple other creative materials I have used to help build and replace panel or holes, fiberglass dry wall tape, aluminum duct tape, great foam..use to aluminum tape to make forms or cover holes to fiberglass over, use great foam to fill large voids then trim to use as backing for fiberglass... works good on rusted out cab corners... have a Great DaY all......
post #9 of 24 Old 02-14-2011, 09:02 PM
stobob1
2007 XK Commander
Great Stuff and an Ice cube. Spray it in the hole and work the ice over it to Stop it from expanding. Also gives it a smooth surface. Rattle can and good as new!!!
stobob1 is offline
post #10 of 24 Old 02-15-2011, 07:19 AM Thread Starter
johnrmclean
Hey Nice additional tip for working with the foam!!!
post #11 of 24 Old 02-21-2011, 01:47 PM
SGTCornewell
2002 KJ Liberty
i prefer to use sheet metal and rivet in place like a battle scarred WW2 plane. seal the edges except the bottom one so water can drain out.
SGTCornewell is offline
post #12 of 24 Old 02-21-2011, 05:17 PM
TheNewbie
It's not a "cheap fix". But I just took mine out with an angle grinder and did some tube fenders last week.
You can see them in the link in my sig.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #13 of 24 Old 01-07-2012, 06:26 AM Thread Starter
johnrmclean
Check out the video on Eastwood's site for their panel re
pacement kit..it shows a real nice video of how to repairs a rusted out hole on a MG fender ....some good tips
post #14 of 24 Old 02-12-2012, 10:47 AM
marzcap328
My father deals to body shops, and every one of his guys I brought it to told me I'd be better off just replacing the fender. Repairing/patching the spot is only going to last for so long, so they said I might as well start fresh. Fender for $100, sprayed by the guy I bought the YJ from, and installed it myself. Good as new.
93 YJ, Black on White
United States Navy
marzcap328 is offline
post #15 of 24 Old 02-13-2012, 04:46 AM Thread Starter
johnrmclean
That is the nice thing about Jeep fenders..pretty cheap and really easy to replace. Easy to unbolt and bolt a new one on. As I recall only an hour or two job. I have done a few of those too. One word of caution. The $100 replacement fenders have very poor corrosion protection. You are best advised to prime and paint the fender WELL before you put it on the Jeep or it will rust out 5 times as fast as the factor fender!!!! I put a couple on my kids Jeep a few years ago and we spray painted it once on the jeep so could not or did not get all the inner surfaces well..it had considerable cancer again after only one winter. Make sure you get the back side and all unexposed surfaces coated and protected well or you will be very disappointed very fast. Best of luck!!
rusted cat Schmuds Engines & Drivetrain 1 10-10-2007 10:01 PM
rusted cat Schmuds Engines & Drivetrain 0 10-10-2007 10:18 AM
Rusted Yj randyheff Fabrication Shop 6 08-21-2007 07:39 PM
POR-15 fix rusted tailgate ? jeepunlimited General Jeep & Off-Road Equipment 4 10-17-2006 03:46 PM
Rusted Fenders ... skid2964 Fabrication Shop 5 02-03-2004 08:52 AM
