Rough Idle - JeepForum.com
post #1 of 4 Old 01-28-2013, 07:42 PM Thread Starter
davelar357
Rough Idle
I just did the head gasket job on my 2001 Jeep Grand Cherokee and now the only problem is that it idles rough when i come to a stop... On the highway it is great, its just at stops... All fluid levels are good, everything reassembled to specs... Idle control, coil pack, crank sensor, power booster and master cylinder are all new... Any ideas
davelar357 is offline
post #2 of 4 Old 01-28-2013, 09:47 PM
Ryman12
Did you try a compression test?
2000 4.0 wrangler 2.5" lift
5 speed JCR Off Road prerunner bumper
Ryman12 is offline
post #3 of 4 Old 01-28-2013, 10:44 PM Thread Starter
davelar357
I had the valve and head resurfaced, new seals... I will probably have to rent a compression tester tomorrow...
post #4 of 4 Old 01-30-2013, 05:39 PM
kenjusa
Still has a distributer? If so be sure all the wires are pushed on good and tight.
kenjusa is offline
