Roll over vent / catch can - JeepForum.com
post #1 of 5 Old 05-14-2012, 11:03 PM Thread Starter
Hiapo
I saw this over on http://pirate4x4.com so I thought I would copy it an do my own right up.
I had been looking for a cheaper alternative to what was out there for catch cans and this fit the bill perfectly. You can once you have all the parts put one of these together in under 20 mins.
Bought a aluminum water bottle from the dollar tree for under a buck. these are perfect because the are threaded inside.
Got a nice air filter from vato zone, this was the most expensive part at 9.99, I need to find a cheaper place to buy these.
Also picked up a PCV filter while I was there like this, so when you tip or roller over it will close.
Went to Lowes and pick up a 3/4 by 3/8 black iron reducer, so I can thread in a 3/8 barbed fitting.
Drilled a hole with a 9/16 drill and stuck a grommet down in there.
Installed the PCV fitting from the mouth of the water bottle using a socket and an extension.
Put the air filter on top.
And the finished product, serves as an expansion tank, vent line, and in the event of a rollover will trap all the fluid then allow it to drain back down into the transfer case.
Here is the original write up. http://www.patriot4x4.com/forum/viewtopic.php?f=2&t=26
www.patriot4x4.com
Hiapo is offline
post #2 of 5 Old 05-24-2012, 01:03 PM
cjjon7
1983 CJ7
I like that. Alot! I wonder would it work as a fuel tank vent too??
cjjon7 is offline
post #3 of 5 Old 11-08-2012, 11:05 PM
lolo75racing
nice idea, do you have any pics installed, thanks
lolo75racing is offline
post #4 of 5 Old 12-05-2012, 07:22 AM Thread Starter
Hiapo
Sure, this is how I had it installed, but I will have to rethink it because I am in the process of building a rollcage.
www.patriot4x4.com
Hiapo is offline
post #5 of 5 Old 12-05-2012, 07:23 AM Thread Starter
Hiapo
I don't see why not, but the pvc valve may not completely stop the fuel from coming out.
www.patriot4x4.com
Hiapo is offline
Shifts but doesn't catch? triplec787 General Jeep & Off-Road Equipment 0 09-12-2011 09:52 AM
Been given a winch.... but it has a catch... ctm9191 General Jeep & Off-Road Equipment 2 03-16-2011 03:15 AM
Ready to Catch the Bug! awsten84 Tires & Wheels 3 04-21-2010 11:08 AM
catch/thud/something in tcase whitie_08 Engines & Drivetrain 0 03-21-2009 07:58 AM
Roll Over Vent Valve BESRK Fabrication Shop 17 03-16-2007 09:02 AM
