I suggest new rotors. The price has gone down a lot in the past few years so they are reasonable. If you resurface them they get thinner so they can fade easier if your going fast lol. And under hard braking they will heat up faster and warp so you get pulsation. Plus if they are turned you can get a directional surface so they squeak. None safety concerns except fading but when i do brakes i either just do pads if im tight on money or get new rotors.
Measure their thickness and see how far away from the minimum thickness you are / if you'd be below that if you resurfaced. This is a basic test a resurfacer would check before work.
I here what you're saying it's up to you. I help out at my friends garage quite a bit and I can turn my own rotor's for free, but on these newer rotors I still just buy new ones. Now on the older ones that have the hub and rotor together, I will turn those because of the price even if you buy just the rotor and press it to the hub, those style are pricy.:cheers2:
Don't waste your time and money. Buy new ones. You will save yourself from having to do them shortly after. Besides, the price difference is not much. Am taking from experience.
Thanks, already done. Got new ones. Only reason I asked was a buddy of mine could reface them. Just got new ones and pads. Next is my u-joint. Keeps breaking...
I am replacing rotors and brakes on my 2007 Liberty , can't seem to get the rotors off . They have not been off before , seems to be just rusted on tight . Tried hitting them from all around(witha piece of wood protecting them ) , just can't seem to shake them off . I will try some Liquid Wrench on them , and i have removed the small retaining tabs on the lug studs , I am missing something else to remove ? I have the caliper and the brake pad clip off of course.
Thanks for any help .
As a though , should I take a propane torch for sweating copper pipes and heat up the rotor , I would be carefull not to damage the hub , just warm it up to maybe loosen it (heat expands metal , right)?
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
