Rattle Can Dash - Page 4 - JeepForum.com
post #46 of 183 Old 03-08-2009, 09:53 PM
cjapgar
cjapgar's Avatar
just rattle canned the dash in my yj looks ok
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
Bacon is meat candy!
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #47 of 183 Old 03-09-2009, 06:18 PM
TheWooginator
I am inspired by the great results...I really hate my tan interior and want to change to gray... I was wondering if anyone has painted the center console... curious how the paint holds up on such a high friction area
TheWooginator is offline
post #48 of 183 Old 03-17-2009, 11:31 PM
green89yj
Got all four wisdom teeth removed yesterday so I had to stay home all day. Spent most of the day painting dash parts. Finished up the tan and started adding green. I'll post pics later. Still haven't decided on what color for steering column and the main dash part (the upper one piece thing that goes all the way across). I have all the guage clusters and glove box/radio surrounds painted.
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #49 of 183 Old 03-18-2009, 11:03 AM
Rigged
I painted my center console black because I didn't like the spice like you and it didn't really hold up that well. Granted I was somewhat rushed, I think if you take your time and do the prep work it will be ok. I had an issue with the cup holders scratching. Other than that it seems to look ok.
Did you say that you aren't using Krylon Fusion you are using some Duplicolor? Is it chip resistant at all?
-Kyle
Rigged is offline
post #50 of 183 Old 03-18-2009, 12:04 PM
green89yj
I am using both Duplicolor Vinyl and Fabric and Krylon Fusion Camo. The Duplicolor is supposed to be sort of a dye/paint and a little more flexible so hopefully it won't chip. The Krylon Fusion is going only on hard surface parts that really aren't gonna get too much abuse so I'm not worried about it. Like I said before, I'll get pictures up soon.
post #51 of 183 Old 03-22-2009, 04:45 PM
91legendary
For those who have painted the grab handle on the dash, HOW THE F DO YOU TAKE IT OFF??? I'm in the process of turning some tan stuff to black and I wanted to do the grab handle as well.
91legendary is offline
post #52 of 183 Old 03-22-2009, 08:45 PM
joeyrossmiller
just a pointer for anyone paintin their dash... i did mine with the krylon fusion hammered texture. and it turned out like crap. dont get me wrong i mean im glad i have the idea to paint it but the hammered texture sucked. i thought it'd look pretty cool w/ that texture but it doesnt turn out like how i thought it would. i think im gonna go over it with flat black, kinda my theme for my jeep.
94 sahara, 4" rough country, 1 1/4" home made shackles all around, 33" trxus m/t, home made cai, hesco tbs, flowmaster super 40, no track or sway bars, 4.0 h/o, home made rocker guards, re-routed the trans vent
GIT R DID, GIT R DONE
joeyrossmiller is offline
post #53 of 183 Old 03-22-2009, 09:14 PM
91legendary
The flat black works very well. I have a tan dash and I painted the speaker covers, the door panels, and the defrost cover thing. It all looks pretty good up against the tan. I'm thinking about painting the console as well. Though I'm not too sure how the paint will hold up on the lid. (my elbow is like perminently attached to it while I'm driving.) I'm afraid It'll rub off. Although I have thought about painting everything but the lid and wraping the lid with some sort of vinyl or leather.
post #54 of 183 Old 03-22-2009, 10:11 PM
green89yj
To get the grab handle off you remove the whole glove box. Undo either the two inner or outer screws where the glove box hinges and then the black trim screws that you can see above and it should pop off. I'll look at mine tomorrow to double check for you.
post #55 of 183 Old 03-25-2009, 09:48 AM
Squint77
Squint77's Avatar
In my 05, I took out the glove box, then removed the two screws that are side my side below the grab handles (they were originally hidden by the glove box). There are two nuts that are directly behind the grab handle on each side. I think it is an 8 or 10 mm- A ratchet works just fine. Then the whole thing comes off.
I painted my interior gloss black with the duplicolor a week ago and it looks great, but there was one spot on the dash that started dripping and after it dried, pealed of surprisingly easy. I am going to attempt to sand and paint again in that one tiny spot. If you are going to attempt doing the entire dash, do what I did- Take off every piece and paint them separately and then spray everything in place that will not come out. I just used masking tape and plastic grocery bags and did not get any paint where I did not want it. Very easy. Getting the insides of the doors off were the hardest. Do yourself a favor and get a $3 tool for removing the window rollers.
Squint77 is offline
post #56 of 183 Old 03-25-2009, 11:11 AM
91legendary
I painted the door panels, the speaker covers, and the defrost cover piece. The entire dash will gradually be turning black over the next few months though. The doors were definitely the hardest to remove. Luckily we already had the window crank removal tool. It took a few minutes, but once I figured out what kind of clip was holding it in, I popped it right off.
post #57 of 183 Old 03-25-2009, 03:38 PM
DT5150
1983 CJ7
i used the duplicolor fabric and vinyl paint on my back seat. started out tan, ended up black. turned out great, looks like a brand new seat.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #58 of 183 Old 03-25-2009, 07:43 PM
04RedTJ
Just did mine last weekend. I am happy with the way it turned out. Now just have to get everything else done inside.
04RedTJ is offline
post #59 of 183 Old 03-25-2009, 09:57 PM
green89yj
Sorry for the late reply. I went and looked at my glove box in the back seat and saw the four nuts (two on each side) they look like either 5/16th or 8mm. Not sure which. There not super tight to get to in a YJ and spin right off. So those four, the (i believe) outer two right above the hinge for the lid, and then the four or five regular little black trim screws above, and your glove box should come out.
I also took the opportunity to remove my old in dash speakers, they weren't hooked up and I'm not even sure if they work.
post #60 of 183 Old 03-26-2009, 12:28 PM Thread Starter
Cole99
After seeing what thedon986 did with the interior of his jeep, I decided to do something similar. Here's the end result.
I used Krylon Fusion Camo, Olive Green.
New Green Jeep Club # 216
My 97 Build/Modification Thread.
Cole99 is offline
pics of painted dash??? anyone ever paint there dash? xj5399 Street Jeep Forum 21 02-20-2013 09:04 PM
Which rattle can? vfrpilot General Jeep & Off-Road Equipment 3 04-14-2007 10:52 AM
OD - Rattle Can or Gun mountaineerjp General Jeep & Off-Road Equipment 2 01-31-2007 09:23 PM
The rattle has got to go. Pantophobia Audio, CB & Ham Radios, GPS, & Electrical 4 10-11-2006 04:04 PM
Please Stop The Rattle!!!! fiy123 Audio, CB & Ham Radios, GPS, & Electrical 7 11-01-2004 08:21 PM
