Quantcast Rattle Can Dash - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > Rattle Can Dash
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 01-05-2009, 06:35 PM   #1
Cole99
Rattle Can Dash
I want to spray paint my dashboard,
the tan section in the Red ellipse, black and maybe some green to match the exterior.
Would Krylon Fusion Camo be fine or would it be better to use something else?
I may also paint the interior plastic on my half doors in the future, so would Fusion work for them also?
Cole99 is offline   Reply With Quote
Old 01-07-2009, 12:48 PM   #2
Cole99
Using the advice I received from another board, I bought 2 cans of Duplicolor Vinyl & Fabric Flat Black spray cans. It has adhesion promoter already mixed, so no need to buy more cans then needed.
I'll be disassembling the dashboard tomorrow and painting it, so I'll post some pictures as I'm painting.
Old 01-07-2009, 03:55 PM   #3
Tompatt
1987 YJ Wrangler
I used Krylon Fusion Black.. works perfectly... its a jeep.
Thomas
-1987 YJ
Jeep Build
Tompatt is offline   Reply With Quote
Old 01-10-2009, 02:38 PM   #4
Cole99
Here's how the spray painting of the interior went. Not 100% done, yet.
Old 01-10-2009, 03:28 PM   #5
Krautzy
What kind of prep work was required before you painted? Looks good. Probably do mine come spring.
Krautzy is offline   Reply With Quote
Old 01-10-2009, 03:39 PM   #6
Cole99
All I did was remove the parts from the Jeep, rub them down with clear ammonia, wait till the ammonia dried, and sprayed.
I only used 2 coats, because I only had 2 cans of flat black Duplicolor.
2 Days after spraying, i can't scratch the paint, no matter how hard I try.
Old 01-13-2009, 08:06 AM   #7
BigPoppaG
You didn't use this?
http://www.krylon.com/products/
Might crack if you used regular spray paint.
1998 4.0L Sport
4.5" SUPERLIFT, Warn Skid Plate, Trail Gear Rock Sliders, JKS Disco's
STEELERS RULE!!!
http://bigpoppag.blogspot.com/
http://www.mpjai.com/
BigPoppaG is offline   Reply With Quote
Old 01-13-2009, 09:00 AM   #8
SpoiledRotten
Roughin' it smoothly
SpoiledRotten's Avatar
I used Krylon for plastic, not Krylon Fusion, and mine is already flaking off. I'll be repainting mine this spring. I think I'll use my pressure washer on my panels as part of the prep work.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline   Reply With Quote
Old 01-21-2009, 02:57 AM   #9
Mitchin
do they make it in yellow can you do a full write up? would like to do only the center console of my jeep yellow
NIGHT CREW #16
Yellow Jeep Club #67
My Build Thread- http://www.jeepforum.com/forum/f22/mitchin-02-tj-sport-973277/
THANK YOU TO 97tjeff, Metalcloak!!!
Mitchin is offline   Reply With Quote
Old 01-21-2009, 07:53 PM   #10
Squealer
Ive used duplicolor vinyl/fabric on the trim piece around the radio in my grand prix and it looks great.
Hmmm, I think I might spray my dash flatblack in the yj.
Squealer is offline   Reply With Quote
Old 01-31-2009, 05:03 PM   #11
southernss
southernss's Avatar
everything still holding up pretty good? no flaking or anything? why did you not do the passenger grab handle and airbag?
1998 tj 4.0 4" skyjacker lift, 1" b/l, 35" wild countrys on american racing wheels, smittybilt bumpers,olympic rocker gaurds, kc titanium series lites,bestop replace a top, corbeau baja seats.
southernss is offline   Reply With Quote
Old 01-31-2009, 05:33 PM   #12
tlendt
Marhyde also makes a good product that can be found at Advance Auto and others. The key to success in my experience has been to wipe everything with laquer thinner right before I spray. It leaves the surface "tacky" and really gives the spray somthing to bond to.
tlendt is offline   Reply With Quote
Old 01-31-2009, 05:55 PM   #13
Cole99
Yep, except for the doors, which get the most abuse. Though for only 2 coats, the doors are doing better then I expected.
I'm going to create a design with the Jeep logo to go over the airbag, and it's been too damn cold to paint the airbag and grab handle.
New Green Jeep Club # 216
My 97 Build/Modification Thread.
http://www.jeepforum.com/forum/f9/modifications-97-sport-pic-heavy-678029/
Old 01-31-2009, 06:07 PM   #14
hawaii
I also used Krylon for Plastics and the upper sections on my door skins have cracked. Glove box door is holding up fine as are the speaker grills and stuff that doesn't get smacked every time somebody gets in. Really like having my interior all black.
hawaii is offline   Reply With Quote
Old 01-31-2009, 06:49 PM   #15
southernss
southernss's Avatar
are you planning on painting them in place or taking them out? i thought that the airbag/cover was reveted in?
Glock Forum
