radiator flush - JeepForum.com
post #1 of 3 Old 12-24-2012, 05:54 AM Thread Starter
woodyfrey
radiator flush
Had to relace the radiator...previously had added stop leak. Garage did not flush the system, or else did a poor job. Radiator and overflow have poor color and clumps of substance that looks like butterscotch pudding. Will proper flush correct.
woodyfrey is offline
post #2 of 3 Old 12-26-2012, 10:34 AM
2jhanna
I have always had good luck with using the Prestone Flush Kit. This is the one the the "T Connector" for the heater hose and hooks up to a garden hose.
I've used this kit on multiple vehicles and flush plenty of fresh water through system with engine off and with engine running. You must first catch coolant in 5 gal buckets, maybe 2, for proper disposal, but after that, just let the water run.
Then add coolant to achieve 50/50 mix.
jhanna
denton county, tx
2jhanna is offline
post #3 of 3 Old 12-26-2012, 04:17 PM
Chace365
Remember, after you flush and drain, use distilled water or else you're going to have more buildup that you'll have to flush out later.
Don't crap where you eat.
Chace365 is offline
