problems with reverse - JeepForum.com
post #1 of 3 Old 12-12-2012, 07:50 AM Thread Starter
jeeperjeep
i just bought a 1997 jeep grand cherokee laredo TSI it has the 5.2 engine. it was reposessed so i dont have to much information on the truck other than i have a problem with going in reverse and drive, i did some looking and found that it is a Quadtrac so it is in 4 wheel all time with 4lo setting but my problem is that when i put it in reverse it seems to have a hard time reversing, and then when i try to turn and reverse i have to mash on the pedal and i can hear some kind of grinding noise. another problem is that the acceleration is terrible and seems to have a hard time shifting. the only modification i can see done to it is new suspension system with 3 inch pucks any suggestions?
jeeperjeep is offline
post #2 of 3 Old 01-16-2013, 01:18 PM
LastDetail
Sounds like your clutch is toast to me. Are you sure you are pressing the pedal all the way to the floor before engaging R or other gears? Also it wouldn't hurt to check your tranny fluid levels.
LastDetail is offline
post #3 of 3 Old 01-16-2013, 10:15 PM
87 JEEP YJ
As grand Cherokee were never offered from the factory with a manual trans and the 5.2l V8 the clutch pedal could not be the issue. I would start to check the fluid level of the automatic trans
JEEPIN A WAY OF LIFE NOT A CHOICE IN LIFE
87 JEEP YJ is offline
