Possibly a cheaper and more reliable quick disconnect. - JeepForum.com
post #1 of 17 Old 05-15-2006, 07:29 PM Thread Starter
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
A while back I was wandering through Tractor Supply and came across a fancy hitch pin.
The pin is 1/2" big but has a coating of plastic that once stripped would prolly result in 7/16" diameter. The only complication i can see is that the shaft needs to be shortened and a new hole needs to be drilled for the pin. If i recall correctly i think the pins were only around $8 each.
I've already ordered my JKS discos so i havent had a chance to give it a try, but if anyone does, let me know.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #2 of 17 Old 05-16-2006, 12:38 PM
bokey
that sounds like a pretty good idea, any pictures of em?
'94 Wrangler - Traded
'87 Trans Am - SOLD
'99 Cherokee Classic
bokey is offline
post #3 of 17 Old 05-16-2006, 03:16 PM Thread Starter
Divinitous
Divinitous's Avatar
No, i noticed them after i already got my JKS disconnects so i didnt bother with em. But i'd assume they'd work.
-Ryan
post #4 of 17 Old 05-16-2006, 09:33 PM
jzmtl
jzmtl's Avatar
Awfuly hard to drill a good hole on cylindrical object as small as that thou, at least for the average home mechanic type.
jzmtl is offline
post #5 of 17 Old 05-17-2006, 09:16 PM
Marauderk
My local tractor supply has that hitch in may different size's and can order just about any size you need.
89 YJ Islander Yellow, 258 Clifford intake holly carb MSD 6
Smittybilt flat fenders, Dick Cepek 3.5 in lift, Warn 8000I
2007 Rescue Green 2d Rubicon 6 speed soft top
Rubicon express 3.5 superflex system,35 in interco truxs mt's, skidrow skid plates, Killby muffler plate
Marauderk is offline
post #6 of 17 Old 05-18-2006, 02:57 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
the trick is to grind/file a small flat spot where you want your hole and then use the center punch.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #7 of 17 Old 05-18-2006, 03:23 PM
Thug Nasty
oooh, good tip sentinal. i wouldnt have thought of that.
97' Blackie with 2.5 4 popper, 3 spd auto and 3.73's, tan top, half doors, tinted rears, 15 X 8 DC1's, 31X10.50 Baja Claws, 2" spacers with hydros, windshield lights (10$ specials), KC grilles so I can look rich, Chicago Electric REW9000 winch, Premier deck and front 5.25's- Xplod 6.5 in soundbar, cheapo discos, bored 4.0 TB and bored manifold, 4.0 intake, Fabtech steering box skidplate, aluminum radiator, 13.4 mpg
Thug Nasty is offline
post #8 of 17 Old 05-30-2006, 06:30 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
or place it in a V block that works too, old shop class trick
RnEmOvr is offline
post #9 of 17 Old 07-10-2006, 09:51 AM
boonethelunkerl
newb question.........disconnect for what????? i know i sound like a newb it is because i am, but i want to learn
boonethelunkerl is offline
post #10 of 17 Old 07-10-2006, 12:18 PM
boonethelunkerl
are yall talkin bout a disconnect for the sway bar?????
post #11 of 17 Old 07-10-2006, 12:39 PM
tj4jay
tj4jay's Avatar
yep that's what there talking about.
Jason
OlllllllO
tj4jay is offline
post #12 of 17 Old 07-10-2006, 12:44 PM
boonethelunkerl
awesome, well i think i might be on the road to being able to figure some of this stuff out...... now all i need to do it learn how to work on my own stuff, that is prolly 5-10 years down the road though, thanks alot
post #13 of 17 Old 07-10-2006, 12:45 PM
boonethelunkerl
what are these.........."JKS discos " i keep hearing people talk about them a lot, just another kinda of sway bar?
post #14 of 17 Old 07-10-2006, 01:58 PM
chim
Good point, and a greater concern for me would be how to actually drill the hole. Those pins are harder than woodpecker's teeth. When in use, they are continually subjected to abuse that is hard to imagine, so they need to be tough.................chim
chim is offline
post #15 of 17 Old 07-11-2006, 11:26 AM
KrazyGimp
1982 CJ5
The discos are what they are talking about using those pins to replace. I will allow you to pull a pin basically and disconnect your sway bar for more articulation.
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
Quick Disconnect Questions C2U5H Fabrication Shop 2 09-11-2009 07:34 PM
Quick disconnect system scouperacer1994 Audio, CB & Ham Radios, GPS, & Electrical 8 03-28-2008 07:36 AM
Where to buy a quick disconnect djXternal Audio, CB & Ham Radios, GPS, & Electrical 3 01-18-2007 09:40 AM
cb quick disconnect eastieboy96 Audio, CB & Ham Radios, GPS, & Electrical 3 04-14-2006 06:47 AM
CB antenna quick disconnect? eastieboy96 Audio, CB & Ham Radios, GPS, & Electrical 3 03-13-2006 01:03 PM
