please help - JeepForum.com
post #1 of 5 Old 11-25-2012, 07:51 PM Thread Starter
lukeverkroost
please help
IVe owned my jeep for a couple of years now and I keep getting this problem where my electric radiator fan stops working and when the jeep starts it splutters on low revs for a sec then the revs rise up for a sec then drops back down and idles normaly! I don't know how the two problems are connected but they are because last time it happened I replaced the ecu and both problems went away that was about 10 months ago, now it's back again, it's starts funny n the fan isn't working! The big fuse clicks when I connect it but I have noticed that there isn't any power to the fan at the plug above the radiator! Could it be from a bad ecu? Also when my fan is going it's runs as soon as the motor is started and doesn't stop until the engine is stopped regardless if the engine is hot or cold! PLEASE help!!! Any info i would be greatfull, cheers from Australia
lukeverkroost is offline
post #2 of 5 Old 11-25-2012, 08:59 PM
redman87
1964 CJ5
Check the temperature sensor it tells the ecm how the control the fuel mix for hot and cold conditions, idle speed ,and the cooling fan. Just a thought
redman87 is offline
post #3 of 5 Old 11-25-2012, 10:02 PM Thread Starter
lukeverkroost
Thanks for the info! The temp sensor is what I was thinking, that would explain how my jeeps been running since the fan stopped. By any chance would you know the location of the temp sensor on the 4.0 i-6, 97 cherokee xj and/or how I could check it? Thanks!
post #4 of 5 Old 11-30-2012, 01:40 PM
itzfreddie
Cant find the post but i believe unlimited04 said "Are you familiar with the vapor lock & heat soak issues many of the 4.0L's get? the engine compartment gets heat soaked, and the fuel in the fuel rail gets vaporized = sputtering until the cool fuel gets up to the injectors & the vapors get cleared."
itzfreddie is offline
post #5 of 5 Old 08-31-2014, 05:51 AM Thread Starter
lukeverkroost
Thanks, found out the problem it was the temp sensor. Im a bit late but... Better late then never. Thanks for the advice way back
