No TC Skid Plate Can I Drive it - JeepForum.com
post #1 of 10 Old 11-20-2013, 04:10 PM Thread Starter
Corbie
Here is some back story:
I have a '97 TJ with a 4" lift and 33's, it has some frame rot. I have a handle on getting that fixed. My problem is this.
My belly skid plate will not mount back to the frame, I have theTC supported with a jack stand for now. I need to move my Jeep, is there a very cheap way to support the TC to move the jeep 5 miles to my buddies shop.
Thanks for your help.
Corbie
Corbie is offline
post #2 of 10 Old 11-20-2013, 04:11 PM
sjones26573
I'd say you best find someone with a car trailer.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #3 of 10 Old 11-20-2013, 05:48 PM
jjvw
jjvw's Avatar
Remove both drive shafts. Tie the t-case to the frame with some ratchet straps and slowly tow the Jeep for 5 miles.
Just a wild thought. Feel free to poo poo the idea.
2003 Rubicon
jjvw is online now
post #4 of 10 Old 11-20-2013, 05:59 PM Thread Starter
Corbie
Will the tear up the engine mounts since all the weight is supported by them now, and it is not exactly balanced.
"Tires are like boobs. They always look big until you have played with them for a while. Then you just want a bigger set!”
-"YEEP” from Virtual Jeep Club
Corbie is offline
post #5 of 10 Old 11-20-2013, 06:06 PM
sjones26573
I would think it could easily damage them, as the rachets wouldn't prevent side to side movement.
Jeep-Owner.com
post #6 of 10 Old 11-20-2013, 06:31 PM
jjvw
jjvw's Avatar
The t-case will swing just the same on a trailer as it will rolling on the street unless it is supported.
Add a couple straps that wrap around the transfer case to prevent side to side swinging. With enough care and cleverness, it shouldn't be too difficult to recreate the approximate ride height of the transfer case and keep it steady enough for 5 miles of slow towing. The motor mounts would not be carrying any more weight than they normally do.
As far as changing the angle of the engine on the mounts (to anticipate a question), we do the same thing everyday with MML and t-case drops. There is a range of flexibility and we are only talking about 5 miles.
2003 Rubicon
jjvw is online now
post #7 of 10 Old 11-20-2013, 08:25 PM
222Doc
222Doc's Avatar
we have used heavy duty ratchet straps to drive a jeep out and back to town with them holding for a broken lower control arm. the guy said it drove great all the way back to get it fixed.
222Doc is online now
post #8 of 10 Old 11-21-2013, 02:42 PM
mattman998
If you can mount the skid to the transfer case you might be able to better control the whole thing. Can you get those bolts in? Can you get ANY of the skid bolts back into the frame?
If you can attach the skid to the tcase you might be able to clamp the skid against the frame.
mattman998 is offline
post #9 of 10 Old 11-21-2013, 09:29 PM
athos76
Hook a strap over the frame, under the skid and over the frame on the other side. Do this front and back of the transfer skid. Then secure the skid, front and back with two more straps. Try to get at least one bolt in each side to hold the skid in place.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #10 of 10 Old 11-23-2013, 06:37 AM
bluecherokee01
I agree this is the best way.
bluecherokee01 is offline
