No heat - JeepForum.com
post #1 of 7 Old 10-25-2013, 04:25 AM Thread Starter
chasmack25
No heat
Have a 1996 jeep grand cherokee laredo and I when I put the heat on I can feel hot air come out for about 20-30 sec and then it gos to cool air. Also for the longest time in hear a air noise from the pass side like its recycling or something.. Easy fix or???
chasmack25 is offline
post #2 of 7 Old 10-25-2013, 04:35 AM
shadowridr1
sounds like a blend door problem.
http://www.heatertreater.net/magento...kee-92-97.html
shadowridr1 is offline
post #3 of 7 Old 10-29-2013, 09:58 AM Thread Starter
chasmack25
I tried the blend motor door and I even blew out the heater core. It's a little better but the same results. HOT HEAT blasts for about 20-30 seconds and it gets cooler. Checked the vacuum hoses and no leaks.
post #4 of 7 Old 10-29-2013, 10:00 AM Thread Starter
chasmack25
Tried the same thing in the video. Plastic in good shape and tried it manually. Also blew out the heater core and checked the vacuum hoses. Same results
post #5 of 7 Old 10-30-2013, 05:51 PM Thread Starter
chasmack25
Well well well,I have to say when I said I "flushed" the heater core was a bit of mis-spoken. I took both heater hoses off and ran a garden hose through each side a couple of times alternating. Do I have heat??? Well if I want to keep a roast hot on my dash I wouldn't have a problem. Thanks for the help from all.
post #6 of 7 Old 11-01-2013, 01:16 AM
shadowridr1
Glad you had better results then I did. Don't get me wrong it's better then it was but it's still not HOT.
post #7 of 7 Old 11-02-2013, 07:54 AM
bap
it took me a few times to get my heat back when i back flushed my heater core,,,it ran clear , flushed it again and the junk flushed out the ran clear got warm but not hot so i flushed again and it got hotter, i ended up flushing several times untill all the brown gunk got out and now i have really good heat..
bap is offline
