Quantcast needs write ups!!! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > needs write ups!!!
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.
Old 04-05-2006, 10:13 PM   #1
Jeepthing88
1994 XJ Cherokee
needs write ups!!!
I saw a couple of great ideas to do to my cherokee and i just need some kinda write ups so i know how do do them. if anybody has anything it would help alot.
-make low beams stay on with highbeams
-taking off rear track bar/sway bar (pros and cons for both would be great)
-air silencer....i saw the write up...and i dont recall seeing anythign like taht in my cherokee...i think they stopped putting them in there but i dont know when. mines a 94. if that helps.
Jeepthing88 is offline   Reply With Quote
Old 04-05-2006, 11:46 PM   #2
XJSport66801
1961 CJ5
I don't know anything about the other two. But I took my rear sway bar out months ago. I haven't noticed it being gone, But I have heard not to take out the front one. I've read everywhere that the rear isn't really noticed unless you tow alot. Hope that helps a little
XJSport66801 is offline   Reply With Quote
Old 04-06-2006, 12:42 PM   #3
Jeepthing88
1994 XJ Cherokee
yea that helps alot thanks...but how exactly do you do it......and whats the difference with removing the sway bar......and the track bar....should i leave one? i thought i heard that the track bar was the best way to counter axle wrap
Old 04-06-2006, 06:44 PM   #4
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Trac-bar centers the front axle. Do Not Remove this! You can remove the rear sway bar, just be aware that you will have a hard time towing and it's generally not recommended without a sway bar.
My 93 has the venturi, but my wife's 01 didn't. Based on the fact your 94 didn't have it, I guess it was discontinued in 94?
Not sure if you would want both high and low beams on with a single sealed beam headlight. Invest in some nice 100w driving lights liek the ProComp ones and that will be just as good....if not better.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 04-07-2006, 03:06 PM   #5
Jeepthing88
1994 XJ Cherokee
I dont plan on taking anything out of the front (track bar or sway bar)....but ive heard people talking about taking the track bar out of the rear and it doesnt effect the ride much...but then i heard about taking the rear sway bar out...and the same results....are they one in the same? even so i'm still not sure how to go about taking it out....
thanks for your advice by the way this is really helping
Glock Forum
