Need advice. - JeepForum.com
post #1 of 5 Old 09-04-2012, 01:26 PM Thread Starter
jeeper06
Need advice.
Have an 06 Tj and the transfer case shifter bracket keeps bending and popping out of place. I want to replace it with a cable system but don't know if I should go with the advanced adapter or the novoc kit.
jeeper06 is offline
post #2 of 5 Old 09-07-2012, 03:44 PM
Ryman12
I got the Novak kit. It was pretty easy to install and has been working great for about half a year now. Very smooth and easy to shift through the ranges. I cant speak for the advance adapters one though...
2000 4.0 wrangler 2.5" lift
5 speed JCR Off Road prerunner bumper
Ryman12 is offline
post #3 of 5 Old 09-16-2012, 12:28 AM Thread Starter
jeeper06
I got the Novak and the install went great until the last part then It was like there was way to much tension on the line
06 tj 4.56 dana 44s 2.5" inch lift on 35"
jeeper06 is offline
post #4 of 5 Old 09-17-2012, 04:39 PM
Ryman12
Could you describe the "tension" your experiencing a little better? Perhaps you didn't adjust it properly the first time around. The adjusting process at the end is very critical to the way the shifter functions. I know that for me it was the part that took the longest. Just follow the directions carefully
Ryman12 is offline
post #5 of 5 Old 09-18-2012, 05:36 AM Thread Starter
jeeper06
I adjusted it as per the directions it lined up perfectly but when I went to shift it it felt as though I would beable to pick the jeep up before it would shift
jeeper06 is offline
