Quantcast My rear hatch will not lock - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > My rear hatch will not lock
Old 03-10-2010, 07:18 AM   #1
jacbank
Anyone have any ideas why my rear hatch will not lock? It will not lock using the master lock switch or the keyfab. If the doors are locked and the hatched is opened the alarm goes off and that is loads of fun.
jacbank is offline   Reply With Quote
Old 03-10-2010, 02:19 PM   #2
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Make sure the power lock mechanism is functioning. You should hear a clunk as tailgate locks function. Most likely the lock rods are loose or out of adjustment. Remove the plastic trim panel, clean and lubricate the lock and latch mechanism with Throttle body cleaner and gun oil. Then locate any loose parts or loose wires and put them back where they belong. Secure any loose lock rods with a zip tie.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 03-28-2010, 11:24 AM   #3
fixer5000
if it sounds like a honking goose shoot it then replace the actuator...about 80 buck and add the price of a few broken door panel clips to it...part numbers can be found on wj jeeps site
" GET THERE FAST BUT ARRIVE ALIVE "
fixer5000 is offline   Reply With Quote
Glock Forum
