MPG tips - JeepForum.com
post #1 of 54 Old 10-28-2012, 05:31 PM Thread Starter
Chace365
MPG tips
This is a bit of a grab bag of info. These are general tips for MPG, and things I've noticed that give me better gas mileage. Things I do have a plus sign for the bullets.
+ Keep the RPM around or below 2200. Slow acceleration is a huge factor for getting better gas mileage.
+ Half a can of Seafoam in the gas tank (with a full tank) and half in the intake manifold. I've gained 1.4 MPG by doing this.
+ Keep the speed 55 and below if you can help it. I've found that going faster than that frequently increases fuel consumption.
+ Use cruise control when the conditions are conducive to using it. This cuts down on RPM spikes when accelerating.
+ Don't idle. If you don't have to sit and idle, don't do it. It's just money that goes down the drain and idling obviously won't get you anywhere.
- Don't carry around excessive weight. The gas mileage tips page on http://www.fueleconomy.gov/feg/drivehabits.shtml shows that 100 pounds of extra weight can reduce MPG up to 2%.
- Air pressure in your tires should be kept to what the manufacturer recommends. http://www.fueleconomy.gov/feg/maintain.shtml states that tires under-inflated by 1 pound can cause a .3% drop in MPG. Properly inflated tires are also safer and last longer, saving you even more money in the long run.
- Use the right type of oil. Using 10w-30 in a vehicle that recommends 5w-30 can reduce MPG by 1-2%.
+ Clean air filters. A clean air filter (I change mine every time I do an oil change) will help with MPG. When mine's dirty, I've noticed a decrease of about 3/4 of a mile per gallon.
- Use overdrive gears (if your vehicle is equipped with such). Using OD reduces engine speed and also reduces engine wear.
- An obvious tip is to never drive more than is necessary. With the cost of fuel going nowhere but up, it's costly to take the long route to your destination, and even just taking that leisurely Sunday afternoon drive costs more money than it's worth. If you're driving to an unfamiliar location with the aid of a GPS, there's usually settings that can be changed to give you the shortest route (by distance) or fastest route (by speed) to your destination. Both of these, and your knowledge of the conditions on those routes can help with fuel consumption as well.
- When driving a lifted truck/ Jeep, making sure your rear axle has the right gearing can help gas mileage, too. Too low of gearing will require more acceleration in order to get up to speed. Higher RPM's = less miles to the gallon.
Hope this helps you get the most out of your gas mileage.
Don't crap where you eat.
Chace365 is offline
post #2 of 54 Old 12-16-2012, 05:03 AM
vizro
good write up thanks
vizro is offline
post #3 of 54 Old 12-16-2012, 04:18 PM
1shotwonder
Hmmm.. Some of these points go hand in hand with what i was trying to say when people say to shift around 2500 to keep in the 4.0's sweet spot..
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #4 of 54 Old 12-16-2012, 09:32 PM
cr4zyfkr
Speaking of MPG...now that refineries are / have switched to the winter blend, I've noticed my '10 GC 3.7L runs like crap and is severely underpowered and gets terrible MPG on 87. Yesterday I threw $20 worth of 91 octane (CA max at the pump) in it, reset the MPG calculator and gained 4 MPG and now I get a whopping 14.6
Why oh why did we buy a full-time 4x4 in southern California is beyond me.
cr4zyfkr is offline
post #5 of 54 Old 12-16-2012, 09:38 PM
karlo
Great tips. I think one of the most effective methods is to be gentle on the gas and brake pedals.
karlo is offline
post #6 of 54 Old 12-17-2012, 08:48 AM
xXchevyXx
Seafoam in the manifold? How do u apply that?
xXchevyXx is offline
post #7 of 54 Old 12-17-2012, 10:18 AM
frostbite91
In order to apply seafoam in the manifold, the way i always do it is start the engine, and remove the vac line from the brake booster(its a bigger line) and then start pouring seafoam in it. The rpm will raise a little, dont worry. If you are not quick after disconnecting the line, the vehicle could die. So if need be, plug the hose w/ your thumb until you are ready to pour in the seafoam.
frostbite91 is offline
post #8 of 54 Old 12-17-2012, 10:21 AM
frostbite91
Just to add, you WILL blow out a crap ton of smoke, so dont do this in your garage. After your seafoam is empty, rev up to about 1500 for a lil bit to get the smoke to calm down. Then drive it around the block a few times(dont forget to plug your brake booster back in)
post #9 of 54 Old 12-17-2012, 10:23 AM
frostbite91
I take no responsibily for f'ed up rigs from my instructions. I have never done this on new new rigs, but it works on carbed, direct injection, and throttle body injected rigs that i have owned.
post #10 of 54 Old 12-18-2012, 07:01 AM
xXchevyXx
Hmm. I might try tht when it's not so f'n cold out. Thnx!
post #11 of 54 Old 12-27-2012, 05:43 PM
mKosel
drive like a grandma, thats what i do!
-KOSEL
mKosel is offline
post #12 of 54 Old 12-27-2012, 08:43 PM
bobjenkins
2% for every 100 lbs extra? Hmm I carry like 150 lbs of crap I wonder if it is more than 3%. Im thinking of going from 33s to 31s just to help with braking. Ive had a few close calls with not being able to stop. I wonder how much the smaller tires would help.
bobjenkins is offline
post #13 of 54 Old 12-29-2012, 09:16 AM
JKolbfleisch
Did you MAINTAIN that 1.4mpg increase or was it only for the tank you ran the Seafoam in?
JKolbfleisch is offline
post #14 of 54 Old 12-29-2012, 07:09 PM
Kevin108
The can says after you get it all in, shut the vehicle off for 15 minutes to let it do its thing.
Also, when I did it, I revved the engine up to about 2,000 rpm and used a section of fuel line inside the brake booster hose to extend it out to where I could sit in the driver's seat, operate the throttle and hold the can of SeaFoam.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #15 of 54 Old 12-31-2012, 09:46 PM Thread Starter
Chace365
As a matter of fact, I have retained an average of ~1.1 MPG (no less than 1) since I used the Seafoam. The ~.3 decrease has usually been from a dirty air filter, which I replace every time I do an oil change.
Chace365 is offline
