Modding the stock tire carrier for 33s(pics) - JeepForum.com
post #1 of 6 Old 11-14-2007, 09:23 PM Thread Starter
flatlander757
So I did a 3" suspension lift and got some 33x10.50s to fit it and knew I'd have issues w/ the spare. I'm not ready just yet to buy a tire carrier/rear bumper, so decided to move my stock carrier up 1" for the tire to clear the bumper(I have no BL).
I used some square tubing(about 1" by 1"?) from Home Depot along w/ a bunch of hardware and some hockey pucks from the Sports Authority to space out the bump-stops.
I did have to cut away a bit of the sides of the rubber gasket on the back of the tailgate where it lets air pressure out of the cabin I guess? When the bracket comes off I'll just get a new one from the stealership.
Heres the notched 3rd brake light bracket so the rim doesn't hit it:
It would hit since it is spaced up about 1" from the tire carrier itself:
My hockey-puck bumpstop extension:
Good look at the brackets:
The bracket bolts to the Jeep w/ bolts going through all the of the square tubing. Then the tire carrier assembly bolts to the square tubing w/ a nut and washer on the inside of the tubing.
While I'm not sure it was necessary or not, I also took a small piece to connect it to the 5th hole where the carrier normally bolts to the tailgate(between the top 2). I figured more support the better.
Here is a video of me closing the tailgate, it's just about as solid as stock.
http://smg.photobucket.com/albums/v2...t=000_2099.flv
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #2 of 6 Old 01-01-2008, 08:32 AM
TSEJEEPERS
We did this to my brothers TJ too. It is a good temporary fix. The stock tailgate can hold the tire and rim for a while but adventually it will bend it. It took a couple of years for his and I am not sure if the tailgate is bent or the bushings are wore out. It is harder than heck to close.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 6 Old 01-27-2008, 11:33 AM
gijoeyb
2010 JK Wrangler
now that is a nice fix
gijoeyb is offline
post #4 of 6 Old 01-27-2008, 09:59 PM Thread Starter
flatlander757
Still holding up great, no loose bolts, no sagging door, no funny noises, etc.
Will be getting one of BESRK's bumpers in the nearish future though once my slew of SYE/CV, rear upper CAs, and rear trackbar are taken care of
Currently Jeepless.
post #5 of 6 Old 02-08-2008, 03:51 PM
bman9089
bman9089's Avatar
I did the same thing and ran fine with it like that for a few months. I wouldn't leave it on there as a permanent thing, just while you are saving for a tire carrier.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #6 of 6 Old 08-11-2013, 01:49 PM
vizro
good idea may give this a shot
vizro is offline
Largest Tire on a Stock Tire Carrier wcusoccer0422 General Jeep & Off-Road Equipment 4 11-01-2008 12:21 PM
You can safely fit a 33" tire on the stock tire carrier on door CB3 Tires & Wheels 35 04-27-2008 02:46 AM
Will this tire fit on my (stock) spare carrier RockyMTN05 General Jeep & Off-Road Equipment 7 01-24-2007 01:00 PM
32x11.5 tire on stock tire carrier TheDiabetic Tires & Wheels 5 05-10-2006 04:19 PM
Largest Tire to fit on Stock Carrier? willydigger Tires & Wheels 3 11-19-2005 12:41 AM
