Mirror relocation suggestions - JeepForum.com
post #1 of 21 Old 05-24-2012, 11:44 AM Thread Starter
noctuurn
2009 JK Wrangler
Hey guys, first post here so don't beat me up too badly...
I'm looking for a solution to my mirror problem. I'd like to take my doors off and stay street legal, and I've been looking at a bunch of mirror relocation kits but can't figure out what's best for me. The weather here is pretty inconsistent so I imagine I'd be removing the doors and putting them back on frequently.
Should I look to get a relocation kit (and if so, which one do you suggest) or should I look into getting temporary mirrors for the empty door hinge (and again, what kind would you suggest).
Thanks in advance!
noctuurn is offline
post #2 of 21 Old 05-24-2012, 11:54 AM
ballantiner
This is what I plan to do: http://www.4x4xplor.com/doorless-mirror.html
Cheap, fast, and easy.
ballantiner is offline
post #3 of 21 Old 05-24-2012, 01:26 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I have a set of A Pillar light brackets that I'm going to use to mount mirrors on.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #4 of 21 Old 05-24-2012, 01:32 PM
cakebatter
I went with a set of mirror relocation and Light brackets on a 2000 TJ. Also easy to install plus I got to buy additional lights (which were also pretty easy to install...as long as you don't mind them connected to your high beams).
cakebatter is offline
post #5 of 21 Old 05-25-2012, 10:01 AM Thread Starter
noctuurn
2009 JK Wrangler
I think I'll go with ballantiner's suggestion for a short-term fix. I like that I can put a mirror on for less than 20 bucks.
cakebatter, what relocation kit is that? I'd probably use that as a permanent solution.
noctuurn is offline
post #6 of 21 Old 05-25-2012, 04:34 PM
castorriver
I also need a good solution...
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #7 of 21 Old 05-31-2012, 05:56 PM
13riverking
1981 CJ7
quadratech
Here's what plan to do 59 bucks for both http://www.quadratec.com/products/13125_102.htm
13riverking is offline
post #8 of 21 Old 06-01-2012, 07:53 AM
E-TICKETRIDE
Just get a set of motor cycle mirrors from the junk yard or local Harley dealer. lots of styles and look great. unless you go crazy with the design they are not expensive.
If it doesn't work use a bigger hammer.
E-TICKETRIDE is offline
post #9 of 21 Old 06-14-2012, 01:39 PM
RioRyan
I have a KLR 650. The mirrors unscrew from the handlebars, and drop perfectly into the upper door hinge on my TJ. So that's what I use. lol
RioRyan is offline
post #10 of 21 Old 06-14-2012, 01:48 PM
Jrdchiropractic
2009 JK Wrangler
Any mirror reloc racket will do for year found drivers side. Passenger side is useless w the door on, and greatly restricted w doors off. I bought rugged ridge quick release mirror for pass side. I run full hard doors in winter and full soft/ no doors the rest of the year. I've had the rr quick on for 1 week. Happy so far. The mirror is round, but has a long enough arm to be seen w any door or no door.
Peace. '09 2door soft top.
09 JK w/ a winch and duratracs
Just enough to get through most of the time,
get stuck sometimes, and still get home
Jrdchiropractic is offline
post #11 of 21 Old 06-14-2012, 01:51 PM
Jrdchiropractic
2009 JK Wrangler
Ps anything from Lange originals is a piece of s$&t. I have "the rack". More like the rusted piece of garbage. Off topic, but I'm p-o'd for the $400+ spent. Didn't even fit right. Punks.
post #12 of 21 Old 06-14-2012, 01:56 PM
Nmusto211
that's what i did. Was pretty cheap and i can remove them in just a few seconds.
Nmusto211 is offline
post #13 of 21 Old 09-08-2012, 10:44 PM
PeejPilot
i took a strip of aluminum approx 1in wide and 1/8" thick cut to length bent one end flat to bolt to the hinge, drilled it and then bent the strip outward to position the mirror further from the body of the jepp. I then took a emergency signal mirror that i had (had a hole in it) put rubber washers on both sides of the glass and bolted down. easy on and off and only $10 in parts
PeejPilot is offline
post #14 of 21 Old 09-08-2012, 10:51 PM
PeejPilot
I also initially had a small mirror that was part of my dads tool hit. the mirror was on a pivot and attatched to a rod ( think dentist mirror) it fits in the hinge hole put would fall through to the base of the mirror so it would stay put. hardly constitutes a mirror but figured i could probably win over a cop with ingenuity if i had been stopped
post #15 of 21 Old 09-08-2012, 11:32 PM
PeejPilot
this is my more permanent mirror
mirror brackets , relocation bracket
mirror relocation brackets bgCJ7 Fabrication Shop 4 04-16-2014 09:50 PM
mirror relocation 2003 TJ 0okamiDigital General Jeep & Off-Road Equipment 6 05-13-2009 06:11 PM
Mirror Relocation Brackets FKemp3 General Jeep & Off-Road Equipment 4 08-01-2008 03:17 PM
i got mirror relocation brackets but can't see passenger mirror thelazerviking General Jeep & Off-Road Equipment 10 12-28-2006 04:38 AM
YJ mirror relocation brackets rustywrangler Fabrication Shop 0 12-22-2006 08:42 PM
