Quantcast looking for a fishing rod holder - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > looking for a fishing rod holder
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 02-07-2007, 09:41 PM   #1
03Wrangler
fishing rod holder... how did you mount it, what did u use.... how do you like it??
looking to make one, CHEAP... i have PVC....
thanks
erick
FOR SALE
Olympic Trunk for 03 TJ
03Wrangler is offline   Reply With Quote
Old 02-07-2007, 09:44 PM   #2
M&C_TJ
for what purpose. on the front so park next to the water or tote them around? if up front then pvc would work perfect and cery cheap. just drill and bolt.
Rock Krawler 5.5 X-Factor L.A. Rock Krawler Heavy Duty Steering System AA SYE and TW CV DS
D44 w/ superior shafts/D44 w/ usa alloy shafts from northridge ARB front and rear
Pro Comp series 97 Rims holding 35" BFG A/T
M&C_TJ is offline   Reply With Quote
Old 02-08-2007, 06:09 AM   #3
03Wrangler
well both tote and hold.... can just be for when im there and throw them in the back when done fishing though....
FOR SALE
Old 02-08-2007, 02:34 PM   #4
mylt1
drill a hole through the pvc and either bolt it to the bumper or run the bolt through from the back side of the bumper then use a nut to fasten it. then you could use a wing nut and have them removeable. or just make a rack for 2 or 3 and make a bracket so you can have 2 bolts that hold it on and just remove the whole thing when not needed.
mylt1 is offline   Reply With Quote
Old 02-08-2007, 07:57 PM   #5
MAX_Xj
MAX_Xj's Avatar
i Bought nice 50 dollar ones at west marine mounted them on a piece of wood and bolted the wood to the bumper looks great in the summer i take them off in the winter.
1998 4dr XJ
MAX_Xj is offline   Reply With Quote
Old 02-17-2007, 10:52 PM   #6
brennanmatherne
I am currently working on a CHEAP fishing rod holder mod as we speak. I purchased two $2.88 white fishing rod holders from Wal-Mart. I spray painted them black with some Krylon Fusion (satin), while I was spray-painting my headlight bezels.
My plan is to mount these rod holders on each a side of the spare tire on the rear bumper. I have bought the 1/4" hex bolts which are 4.5" long. I assume, I'll just affix a piece of wood (with holes drilled) between the Jeep and the rear bumper and tighten the nuts on the bolts and Wallah!
Of course, I will take pictures once I am through and post them here. But ultimately, this will give me two rod holders on the rear bumper of my jeep for around $10 altogether.
brennanmatherne is offline   Reply With Quote
Old 02-18-2007, 06:37 PM   #7
Bigbob
Bigbob's Avatar
Originally Posted by redYJ
fishing rod holder... .... how do you like it??
I've been know to hold a fishing pole now and then- - - -
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 02-18-2007, 06:52 PM   #8
03Wrangler
what size PVC would be best?
FOR SALE
Old 02-27-2007, 11:38 AM   #9
connordanny
I used 1.5" PVC, a U bolt and a regular bolt.
It held my Rod from Baltimore to the Outer Banks!
I also zip tied one to the rear rollbar so the hook wouldn't fly back and hit me in the face while I was driving:
They won't necessarily help you catch any fish though. This is the only nibble I got the whole week:
Jeep I: '91 YJ, 33" Baja Claws, rust
Jeep II: '01 TJ, RE 4.5 SF, 35" Pro Comp MTs, SYE, Tom Woods CV Driveshaft, A to Z rockers/tire carrier/winch plate, Warn M8000, Skid row eng and gas tank skid, Line-x interior, D44 in the rear, Aussie up front
connordanny is offline   Reply With Quote
Glock Forum
