Leaking soft top around doors - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Leaking soft top around doors
Poison Spyder Ricochet RockersROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Engo winches available at www.rockridge4wd.com! Free shipp
Unread 04-30-2014, 01:16 PM   #1
rlomax216
I have a 2007 Jeep Wrangler and have owned it for a little over a year. After a very rough winter here in Cleveland I am now having leaking issues with my soft top. It is leaking on the driver and passenger doors. It will drip down directly above the door handles on each side. If there is a good rain I have to ride with paper towels in that part of the door and change them throughout the day.
After a little bit of time so much rain is coming in the sides that my seats, steering wheel, and floors are soaked. I took it into a Jeep dealership to get it checked out by their too specialist and they told me I needed to get it reseamed and a new header. The cost would be $1,300 to do this which is unbelievable. The header is just leading to additional road noise which I can deal with but this leaking at the top of the doors drives me nuts.
Anyone have any suggestions on what I can do?
Do you think if I bought a frameless soft top replacement it will do the trick or still leak in by the doors?
Any ideas are appreciated!
rlomax216 is offline   Reply With Quote
Unread 05-01-2014, 07:14 PM   #2
Walkersports
I had a similar issue, turned out it was the gasket around the upper doors, upon replacing my top the gaskets were not sealing correctly when they were new causing them to develop a memory, I had to take them off and heat them up with a hair dryer several times to get them to seal properly.
Walkersports is offline   Reply With Quote
