Is Krylon Fusion Flat Black Closest Match for Flares? - JeepForum.com
post #1 of 16 Old 08-17-2009, 06:05 PM Thread Starter
Jeeper123
My 2004 Jeep TJ fender flares are in okay shape; but, there are couple of scuffs I'd like to touch-up.
It's NOT bad enough to justify the time/effort to repaint the whole flare(s), yet. So, I'd just like to touch-up as good as possible....
Will Krylon Fusion Flat Black provide the best match to the original fender flares?
Or, is there something else, either color/brand/process, that would allow a good touch-up?
Any Experiences? Thanks Much....
Jeeper123 is offline
post #2 of 16 Old 08-17-2009, 06:46 PM
jeep95xj
1995 XJ Cherokee
Use spray on bed liner. Gives it a little texture and looks awesome. Plus it's flexible so it wont chip off.
jeep95xj is offline
post #3 of 16 Old 08-17-2009, 07:09 PM
cerebrus
If they are just bends where the plastic has turned kinda whiteish you can try using a heat gun to blend it out. Never done it myself but have seen some people have some luck with it. As far as just touching up a few spots, I don't think you will be able to match the fading with just about anything so you might as well paint the whole thing.
cerebrus is offline
post #4 of 16 Old 08-17-2009, 07:51 PM Thread Starter
Jeeper123
Yeap--I've got the whiteish spots. I've seen the heat gun suggestion by others. Not having used the heat gun approach, I'm a bit nervous and suspect it would be easy to screw-up.
How/Where can I find out more about how to do the heat gun approach?
post #5 of 16 Old 08-18-2009, 02:59 PM
cerebrus
There are a few different youtube videos up with people doing it. They did a piece on this on Trucks on Spike as well. The trick seems to be to keep the gun moving, the goal is to heat up the plastic to the point where it is glossy but before it actually starts to melt. That is all that need be done. No rubbing or shaping. Some people on there were actually using torches but that seems to be trouble waiting to happen. You still might run into the same problem of the spots you work on looking different than the rest of the fender. Take your time and it shouldn't be too hard to work out.
cerebrus is offline
post #6 of 16 Old 08-19-2009, 01:43 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
i used satin black. flat doesnt quite shine enough
1990JEEPXJ is offline
post #7 of 16 Old 08-19-2009, 08:26 AM
donie
2014 KL Cherokee
Not to hijack the thread, but is the fender flare color the same as the newer (07-09) hardtop color?
Thanks.
14 Cherokee Limited 4x4
73 K7UTA
donie is offline
post #8 of 16 Old 08-20-2009, 08:46 AM
yankee07
my whole jeep is just about painted with krylon spray paint hahah...if you do a good job and then put a clear coat on top of it, it looks great
Green 93 XJ 4.0 L 4WD 4 door
RE4.5" l 33x12.5x15 Geolanders MT plusl Cragar soft 8's
yankee07 is offline
post #9 of 16 Old 08-21-2009, 04:17 AM
younts22
I doubt it'll blend in with the rest of the flare. I'd take the time and paint the entire flare.
younts22 is offline
post #10 of 16 Old 03-24-2011, 08:46 PM
jdgrip
2004 KJ Liberty
They actually have a Krylon Fusion that is a "Textured" black paint, used on mine.
jdgrip is offline
post #11 of 16 Old 03-24-2011, 09:30 PM
2005X
thats what i use for my tubes, fenders and sliders
2005X is offline
post #12 of 16 Old 03-27-2011, 09:02 AM
BLK00TJ
I tried using a heatgun on mine and they came out spotty probably due to the fact that I tried it while it was 12 degrees outside. On a warmer day I used Krylon Fusion satin black and they came out very nice. However, later I painted my bumpers (incuding rear milk jugs) and mirrors with Rustoleum Truck Bed Liner and it was really nice. This spring I'll be repainting my flares with the liner. The texture is perfect for flares.
BLK00TJ is offline
post #13 of 16 Old 05-09-2011, 12:21 PM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
I don't think you're going to have any luck just doing touch ups. Every fender flare out there is a different color, based on age, exposure to the sun, etc.
Take the little bit of extra time to do the whole flare, it'll look much better!
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #14 of 16 Old 05-17-2011, 02:36 PM
05WK98TJ
Use krylon fusion satin with clearcoat, looks great and lasts forever
05WK98TJ is offline
post #15 of 16 Old 05-20-2011, 04:56 PM
Carl135i
Use SEM Trim Black. Part #39143 It looks better than the Krylon Fusion (I tried both) You can get it at most auto paint supply stores. The heat gun trick only lasts for a short time. I just refinished my flares and I am very happy with the results.
Carl135i is offline
Krylon Fusion Flares CapnDik Technical Articles & Write-Ups 15 08-21-2010 03:24 PM
Krylon fusion SlipperyNutt Cheap Tricks & Fixes 15 11-01-2009 12:53 PM
Other uses for Krylon Fusion? Jebussaves0 General Jeep & Off-Road Equipment 16 08-09-2008 06:19 PM
Where to Buy Krylon Fusion SuperWade2 General Jeep & Off-Road Equipment 6 04-16-2007 03:42 PM
Krylon Fusion vs. Duplicolor Bed Liner on Flares miked02 General Jeep & Off-Road Equipment 18 04-04-2006 09:04 AM
