Key/cylinder lock '79 CJ7 Heelllpppp! - JeepForum.com
post #1 of 7 Old 05-28-2012, 09:47 AM Thread Starter
JimmyFrank
1979 CJ7
Please see the attached picture, it looks like it should be an easy removal. I've already ordered a replacement cylinder and I want to take this one out and get the column cleaned up for when it comes in. Any tricks?
Sometimes you have to choose between what is right and what is easy.
JimmyFrank is offline
post #2 of 7 Old 05-28-2012, 10:00 AM
wicked99wj
from what it looks like you need some shoes. lol but on note it looks like all you need to do is remove the silver cylinder ring on the back of it and pull it out.
wicked99wj is offline
post #3 of 7 Old 05-28-2012, 10:07 AM Thread Starter
JimmyFrank
1979 CJ7
Lol. I noticed that when I took the picture. Shoes check :-)
The silver cylinder is all one piece it looks like it. I don't want to beat it to death and ruin the actual column holder piece.
post #4 of 7 Old 05-29-2012, 12:34 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I thought on alot of these GM style ignitions, you turned the key to run and could pop it out.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #5 of 7 Old 06-01-2012, 06:49 AM
aggiejon
1979 CJ7
Any cheap tricks on repairing the lock cylinder from popping out? About to go to using a tractor ignition switch on the dash since mine falls out every time I go somewhere.
aggiejon is offline
post #6 of 7 Old 06-01-2012, 07:16 AM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Short of replacing the ignition lock cylinder, no. If this is not a DD, I would maybe consider a push button start and a kill switch. You could also hide another switch under the dash that would prevent it from starting when the switch was engaged.
dagr8tim is offline
post #7 of 7 Old 06-01-2012, 08:28 AM
aggiejon
1979 CJ7
that's been the plan. i'm putting a keyed universal ignition switch in the dash. Its not a DD but gets driven frequently and it sure is a pain to hunt all over the floorboard for the key and cylinder in order to turn it off every time.
aggiejon is offline
