Keep your door's soft windows partially open & NOT BLOW OUTWARD! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Keep your door's soft windows partially open & NOT BLOW OUTWARD!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 11-23-2013, 04:52 PM   #1
jawasan
I am not sure if there is another way I am not aware of...but if the soft windows are partially open, well they always seem to get sucked outward when driving. Sucks, literally and figuratively...either all the way open, or you have to hold it with one hand part way.
So here's what I came up with, I am sure I'm not the first to have thought of this, but here it goes....
I purchased to locking clamps and some Velcro strapping at HF and this is the result, not much to it....
http://www.jeepforum.com/forum/f22/finally-starting-yj-5-3l-bdturnkey-4l60e-novak-swap-2935953/
jawasan is offline   Reply With Quote Quick reply to this message
Unread 11-23-2013, 05:14 PM   #2
irnmadn88
I did the same thing with my YJ. I just zip tied them to the window frame and tucked them in behind the velcro when I wasn't using them.
irnmadn88 is online now   Reply With Quote Quick reply to this message
Unread 11-30-2013, 08:52 AM   #3
Firefyter-Emt
I used a pair of suspenders and one of tarp grommet repair kits. I cut the suspender to the length I wanted, and then folded the cut end over and installed a grommet. The grommet hooks through the middle leg of the upper door. The nice thing is that there is enough stretch to give it a little adjustment. I like to hook one of the corners and fold back a triangle.
Firefyter-Emt is offline   Reply With Quote Quick reply to this message
