JK - Hand Throttle - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > JK - Hand Throttle
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineCHASSIS SAVERô Labor Day 2 for 1 Sale!!!JKS Flex Connect in Actions!
Unread 08-31-2015, 05:56 PM   #1
Off Pavement
Off Pavement's Avatar
JK - Hand Throttle
I installed a cable hand throttle on my '13 JK...
The parts required for this install are shown with the exception of 6 self tapping screws, and a small "L" bracket that the cable adjuster goes through. My initial design had me bending the can opener and using the small hole for the cable adjuster, but when I tried to bend it, it broke.
I started by installing the bicycle derailleur control on the shift arm at the most convenient and comfortable position. Most bike shift controls have a pin type tightener, but I removed it and replaced it with a screw knob for easy adjustment for the times I want to use the throttle to adjust engine RPM for winching...
Next I routed the cable housing through the center console and above the accelerator pedal.
I drilled a 1/4" hole in the accelerator arm for a 2 1/2" 1/4" bolt. I started with a fender washer, nylon washer, fender washer, then a nut. This created a non binding attachment for the cable to the pedal. Then another washer that goes against the brake pedal side of the accelerator arm, then a fender washer on the passenger side of the accelerator arm, a lock washer, and a nut to tighten the whole bolt assembly to the pedal.
Carefully determine the best location for the pulley and attach to the firewall using self tapping screws. I used part of the can opener as a shim behind the upper pulley support.
Place the Derailleur cable in the control and cable housing and start test fitting for the pulley. This is a PIA and took a lot of tries and fails to get the correct cable tension...
With the carpet installed...
While parked, the throttle is extremely touchy. Moving the lever very slowly gets nothing...nothing... then 2200RPM. A little playing with the lever and I can control RPM effectively from around 1200 RPM and above. Driving is a different story as the drive by wire accelerator works well with the hand throttle. It's easy to move along at extremely slow speeds using the HT with the ability to increase and decrease speed.
If you get the right stuff the first time, you can do this mod with all new parts for less than $40.
Do you need one of these? I'd guess no, but it's fun and your buddies don't have one yet.
Please Support Multiple Use Of Public Lands!
www.rv-camping.org
Off Pavement is offline   Reply With Quote Quick reply to this message
Unread 08-31-2015, 10:50 PM   #2
222Doc
222Doc's Avatar
The only thing i see that kinda looks like trouble is if the cable gets snagged when in foot mod. I would guess that the way with these fly buy wire would be to have it control the computer then you could get exact rpms but from the a thumb. i wonder what the computer would do if you had two signals lol i would bet we get limp mode. reading out of range bla bla.... make you miss the old jeeps at times. Love hate think these jks lol
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is online now   Reply With Quote Quick reply to this message
