J.B. Weld, Cold Weld, Epoxy... Show what you've done! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > J.B. Weld, Cold Weld, Epoxy... Show what you've done!
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 09-24-2012, 03:05 PM   #1
backyardjeeper
1992 XJ Cherokee
Let's see some pictures and stories of what you've done with J.B weld or anything like it (j.b. qwik, etc. any kind of cold-set epoxy).
I once used it to hold the steering wheel of a law mower onto the shaft when the splines were stripped.
I also used it on a 79 Honda cx500 to keep the intake manifold sealed when I snapped off a bolt.
92 xj on 235/75/15's. $2000 into a $400 dollar jeep.
backyardjeeper is offline   Reply With Quote Quick reply to this message
Unread 10-01-2012, 07:28 PM   #2
rjbruzan
I used JB Weld to seal an XJ sending unit that was leaking where the wires come out of it. Took the sending unit out,wire brushed the area, wiped off with Brake Kleen and sealed up both sides with a healthy dolup of 4 hour fast dry. This sending unit is submersed in gasoline when the tank is full. 2 years now and no leak at all.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline   Reply With Quote Quick reply to this message
Unread 10-25-2012, 04:29 PM   #3
416469
Plumbers Goop works too however you need 24hrs to dry. Also try the Oatley putty from home depot the kind you knead in your hand that only takes an hour to become hard as steel.
416469 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2012, 10:14 AM   #4
jeeper06
I used it to hold my skid plate up after to of my bolts were stripped held up for a week before I tapped the bolts
06 tj 4.56 dana 44s 2.5" inch lift on 35"
jeeper06 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2012, 05:01 PM   #5
dnuccio
Not jeep related but my dad smashed the oil pan on our minivan during a camping trip and we used that quick steel stuff to plug the hole until we got home
dnuccio is offline   Reply With Quote Quick reply to this message
Unread 11-04-2012, 05:04 PM   #6
backyardjeeper
1992 XJ Cherokee
I used it to repair a Volvo windshield wiper after th shaft stripped out.
Unread 11-10-2012, 10:12 PM   #7
cory4um
Used it to repair a hole in an engine case on my atv.
Kawaski Lakota popped the chain and took out part of the casing where a bolt secured it.
Cleaned the hole well and used a piece of metal to cover the hole, the hole waS about 1/2'' by 1'' maybe. Used jb on the outside and inside to hold in place. has been working for 3 years now.
cory4um is offline   Reply With Quote Quick reply to this message
Unread 11-23-2012, 11:18 AM   #8
mateas
JB Weld will always be in the emergency kit. Used it to plug the radiator drain plug when I broke it off wheeling once, more recently used it to plug the holes in the body where the tailgate hinge bolts were, let it dry, sand flush, paint, and presto, incredibly cheap bodywork that nobody in the world can tell was ever done!
'06 LJ, Bestop Trektop NX, Smittybilt front/rear bumpers, 4" RC long arm lift, Currie HD steering, 35x12.50x18 Toyo Open Country MT's, 18x9 Fuel Hostage's, matte black special.
mateas is offline   Reply With Quote Quick reply to this message
Unread 11-23-2012, 01:08 PM   #9
rjbruzan
You are all the kind of guys Id wheel with. Able to figure out how to get home without any whining.
Ron
Unread 11-23-2012, 08:15 PM   #10
backyardjeeper
1992 XJ Cherokee
I like that idea. Wonder why we don't use cold weld instead of bondo.
Unread 11-30-2012, 08:09 PM   #11
CoastieShep
Years ago, a spark plug popped out on my 71 VW bug. Took some of the 2 part putty stuff, smeared it around the threads of the plug and shoved it back in. Waited around for a half hour and drove it 15 miles back when it popped out again just as I was parking. Probably would've lasted longer if I had been able to let it fully cure.
CoastieShep is offline   Reply With Quote Quick reply to this message
Unread 12-07-2012, 12:34 PM   #12
Indy
No pictures but fixed the exhaust headers on my last boat. Previous owner didn't winterize and they froze and cracked. He brazed the cracks and painted, I didn't notice until I was on the lake a few times and found they were leaking. Ground out the braze, heated them up with a torch and filled. With heat, JB runs like water so it will fill the cracks/pinholes instead of just going on top. And it hardens like normal once it cools down. Painted and leak free afterwards. I've done the same with a radiator that took a rock hard enough to punch a hole in it.
I'm the only gay eskimo.
Indy is offline   Reply With Quote Quick reply to this message
Unread 12-08-2012, 10:10 AM   #13
backyardjeeper
1992 XJ Cherokee
Wow. Thanks, imma keep a blowtorch in the jeep now. along with my cold weld.
Unread 12-09-2012, 01:44 AM   #14
smokey1985
So you can put jb in a radiator and it will not stick to nothing but the leak then harden when it's cold and won't hurt nothing or what ? Thanks
smokey1985 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2012, 01:51 AM   #15
Ripper3494
fixed a hole in my aluminum radiator with it. and about a thousand other things lol
build thread:
[url]http://www.jeepforum.com/forum/f22/94-yj-6-0-build-spud-1218315/[/url]
1997 ZJ limited - BONE stock
[url]http://www.jeepforum.com/forum/f12/alternator-welder-write-up-1301614/[/url]
[url]http://www.jeepforum.com/forum/f12/tj-uppers-yj-half-doors-hard-top-installation-1417686/[/url]
RC vs BDS
[url]http://www.jeepforum.com/forum/f12/rough-country-vs-bds-1461555/[/url]
Ripper3494 is offline   Reply With Quote Quick reply to this message
