intermitten wipers - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > intermitten wipers
~Artec JK 1 TON SWAP~** FALL SALE on all Jeep Optic Armor Windshields **Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-14-2014, 02:11 PM   #1
joeyl16
intermitten wipers
I have 2000 wrangler with out intermitten wipers. Can i just change the switch on the column to a intermitten? Thanks joe
joeyl16 is offline   Reply With Quote
Unread 06-23-2014, 06:15 PM   #2
TJ4Jim
Yes you can, I picked up an OEM switch at Daveys jeeps for $25 if I recall
TJ4Jim is offline   Reply With Quote
Unread 08-25-2014, 07:02 AM   #3
tators
Since this is the "cheap tricks" section....
Go to your local Pull-a-part junk yard and get a wiper stalk from a dodge neon.... Think mine was $4 or $5 bucks... plug and play !
tators is offline   Reply With Quote
