Improve mpg.. - JeepForum.com
post #1 of 73 Old 07-21-2011, 11:24 PM Thread Starter
Flipcyd7
Improve mpg..
Its a Jeep..I know that, but what are the most efficient mods for improving mpg. I have a 2000 TJ Sport 4.0 I6. 33 12.50s and 3in lift. Thought about K&N cold air intake but because of this site have decided against. Already have Poweraid TBS installed. Any tips are appreciated. First time Jeep owner but will own nothing else ever.
Flipcyd7 is offline
post #2 of 73 Old 07-22-2011, 01:44 AM
Boodyrider
Short answer: buy a daily driver that gets good fuel economy. Prius comes to mind. Otherwise, put Jeep back to stock and do a tune up. Throw away the TBS.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #3 of 73 Old 07-22-2011, 01:59 AM
neatocj
1981 CJ5
Similar to what ^said....the best mod for a jeeper to get better mileage is to not drive it.
that or have small tires, keep the top and doors on and be nice to the skinny
Your not pushing the limits of your jeep until your on your side, then something breaks and it's time to go home.
'70 Camaro - Almost Done
'81 Cj-5 - SOLD
'06 MegaCab Cummins- Great White
neatocj is offline
post #4 of 73 Old 07-22-2011, 05:39 AM
hdsport
2008 WK
My 2000 TJ
I have a 2000 TJ, 4.0L, 5-speed, stock 3.07's, 235's, 105,000 mi and all stock.
I get 18-20 mpg all of the time. Got better until they mandated 10% ethanol in gas.
Compared to what I see on this Forum, this is pretty good mpg's.
I don't put my foot in it or do anything stupid as I drive. She treats me good, I treat her good.
No K&N, throttle body spacer, etc.
Today, a new power steering gear....can't stop the current leak.
Was 102 deg F yesterday, more today...can't wait to do some doors off touring today.
2001 Winnebago Adventurer 32v Motor Home
2008 Jeep GC Limited Toad, 4.7 L V-8, QTII
US Army Vet, 8th Army, 11th Evac SMBL Hospital, Pusan, South Korea
In God We Trust
hdsport is offline
post #5 of 73 Old 07-22-2011, 05:23 PM
soldierofchrist77
soldierofchrist77's Avatar
Bigger tires without matching gears will greatly decrease gas mileage. Were your gears upgraded with your tires? You should be running at least 4.10s with your 33s.
soldierofchrist77 is offline
post #6 of 73 Old 07-22-2011, 05:53 PM
t-fids
Best advice I was given was don't drive anywhere fast. Mine's a 98 4 cyl 2.5L with 33's and 4.10's. It's a jeep and we all know they mall crawl, so, in saying that, sport the mall crawl! Don't go anywhere in a hurry, if it's stick, shift at an economic RPM. I'm surprised with my $60-70 tank (CND), that it lasts me 7-9 days.
1998 TJ, 2.5L 4 Cyl, 4.10's, 3" Zone Suspension, 33x12.5x15 Hankook Dynapro MT, Pro Comp 52 steelies.
t-fids is offline
post #7 of 73 Old 09-09-2011, 04:07 PM
chopstix333
I'm with t-fids... I also got a 98 2.5L on 33s and stocks gears and easing off the gas can save some $$$! Besides, you got a lift and big tires.. no one can bully you on the road.. so driving slower than traffic ain't gonna hurt ya
'98 Jeep Wrangler 2.5L | 4" Pro Comp Lift | 33x12.5x15 Dunlop Mud Rovers | Two 10" Polk Audio Subwoofers | 2 Amps (800w Eclipse and Alpine MRP-1000 Mono) | Kenwood Head Unit | Ham Radio w/ Comet SBB-7 Antenna (Call Sign: KK4BUE) |CB Radio | Hella Vision Plus Conversion with 50w 6k HID bulbs | Lotta Lights |
chopstix333 is offline
post #8 of 73 Old 09-20-2011, 09:07 AM
GromMudder757
i run the speed limit, and i dont speed in my jeep ever. I get 20 mpg with my setup 2.5l 4.5" lift, pro comp 33s. First thing first replace ur fuel filter!!! makes a big difference! i also shift at 2000 between every shift! keep ur right foot out of it
My first jeep - 1992 YJ, 2.5, 5 spd, Rough Country 4.5" suspension lift, Brush Bar, 33x12.50 Dakota ATs, Uniden 510 cb
My mom, and brother have really helped me a lot with this project, if it wasnt for them my jeep would be in peices!
GromMudder757 is offline
post #9 of 73 Old 09-20-2011, 11:01 AM
t-fids
Grom, any fuel filters to recommend? Also, how expensive and can you do this yourself? What kind of differences have you noticed?
t-fids is offline
post #10 of 73 Old 09-20-2011, 12:55 PM
sequimbillyheep
13.4MPG on my 97. I run 4.56s and 33s, 35s off road. Im not complaining about my MPG, cause i expect it.
97 TJ stump crawler. locked. not modified too the extreme but does what I want when I want unless its passing on the freeway!
sequimbillyheep is offline
post #11 of 73 Old 09-20-2011, 02:27 PM
sgtmajor138
2009 JK Wrangler
Right at 17 mpg with 4.0L, Auto, stock gears, 33s, and a fresh set of plugs. The fresh plugs helped a bunch.
'09 JKU Wrangler - Seize the Opportunity!
sgtmajor138 is offline
post #12 of 73 Old 09-22-2011, 11:02 PM
GromMudder757
I use the napa gold series it cost me 12.97 on my shop acc with them and it made a huge difference. I recommend doing a tune up on the regular because the plugs tell the story of the motor. That's all there is too it, you have to read the plugs! I got 22.3 mpg on the highway today I was excited
post #13 of 73 Old 09-22-2011, 11:39 PM
Drix
I notice a lot of people buying Throttle body spacers... DONT! for the love of god and physics dont do it. Throttle body spacers came from Carbs, they made the carb sit up a bit higher allowing fuel and air a bit more time to mix. kinda like putting on a taller intake.
Unless you Have a TBI set up you could make out. on modern EFI engines where fuel is injected through the rail and into the manifold your not gonna have any effects.
The only way to increase your MPG will
1. Control the foot that pushes the skinny pedal.
2. Keep up on regular Maint.
3. Buy small cheap old 4cyl DD (This is what I did) Plus I paid less for the Corolla then what it will cost me to replace my tires after they wear away on the pavement.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline
post #14 of 73 Old 09-23-2011, 09:48 AM
GromMudder757
hahah i agree 100 percent! I bought a 88 zuk sami for 500 runs drives inspected!! Only 2 small rust spots, 9" lift, 33s, 5 speed, no exhaust, 24.6 mpg if im easy on it!!
post #15 of 73 Old 09-30-2011, 04:50 PM
TLATEOTW
try using scangauge II, to monitor your current MPG, it'll help.
TLATEOTW is offline
How can I improve my welds? StupendousMan Fabrication Shop 12 12-14-2010 12:50 PM
Improve Handling alexrule123 Street Jeep Forum 21 01-26-2007 08:31 AM
Improve 2.5 performance fatdutchmn Engines & Drivetrain 28 05-14-2006 05:15 PM
how can i improve my ride? jugger Tires & Wheels 2 05-04-2002 06:55 AM
How can I improve my sound Londonboy Audio, CB & Ham Radios, GPS, & Electrical 9 09-29-2001 03:46 PM
