I don't have a book for my '10 JK. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > I don't have a book for my '10 JK.
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 05-26-2013, 10:33 AM   #1
kurtmax1
I need to know what the torque setting is for rotating tires. Also how do I reset the change oil message. Thanks for the help.
kurtmax1 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 06:31 PM   #2
Trombino
1978 CJ7
I have always torqued the tires on all my vehicles to 100 ft./lbs. You should be good anywhere between 85 and 100.
As for the oil life, a quick Google came up with this -- definitely more straight forward than on my Accord and Odyseey:
To reset the oil change indicator system (after
performing the scheduled maintenance), refer to the
following procedure:
1. Turn the ignition switch to the ON position (Do not
start the engine).
2. Fully depress the accelerator pedal slowly three
times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary repeat this procedure.
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline   Reply With Quote Quick reply to this message
Unread 05-31-2013, 03:28 PM   #3
kurtmax1
Thanks a ton.
Unread 11-04-2013, 02:29 PM   #4
abock33
Pm me your address. I will send you the owners manual from my 09' I got rid of it earlier this year and forgot it wasn't in the jeep at the time.
"Of course he likes your idea. When one retard on the short bus licks the window, the others think it's a great idea and start licking like crazy!" Rob99
abock33 is offline   Reply With Quote Quick reply to this message
