I did this ________ for $100 OR LESS! - Page 72 - JeepForum.com
 8Likes
post #1066 of 2228 Old 11-03-2012, 10:18 PM
DezertXj88
1990 XJ Cherokee
Clicky clicky my firneds
http://www.jeepforum.com/forum/f128/...t-bar-1429415/
output pics should be up in the next few days. Going back out tomorrow with a Nikon d600 to get some nightime pictures!
DezertXj88 is offline
post #1067 of 2228 Old 11-04-2012, 11:36 PM
Wuchagonnado
Under 100?
Wuchagonnado is offline
post #1068 of 2228 Old 11-05-2012, 05:18 AM
murrdog66
Originally Posted by Wuchagonnado
Under 100?
My thoughts too!
murrdog66 is offline
post #1069 of 2228 Old 11-05-2012, 12:36 PM
Moondog
The K&N was $45 of it. The rest you can pick up at Home Depot. You do have to have a guy who can bend a 45 degree angle in the pipe. ( There is a pipe you can get for $50 that is already bent but then you are in the $140 range) The 3" couplers are $3.99 at home depot and are EXACTLY the same as the $10 - $30 ones you see online if not better. customizing the air sensor is the most time consuming part. I cut the housing out of the original pipe and fabricated it into the aluminum pipe. I noticed a huge gain in throttle responce and power at 2000RPM .
Jeep air filter K&N.png   Jeep air intake on hood.png   Jeep air sensor.png   photo (1).jpg   Jeep pipe.png
Moondog is offline
post #1070 of 2228 Old 11-05-2012, 12:51 PM
Moondog
The part in my hand was just recently added. That is a $10 part for a rice rocket for the air sensor. It does not fit a Jeep sensor so you have to cut out the housing of the stock pipe and dremmel it down and use some gasket maker around the edges. Advanced Auto carries the part. The 90 degree tube is also at Advanced Auto and cost $10. Attached is a picture of the intake before the extra $20 in parts.
Moondog is offline
post #1071 of 2228 Old 11-07-2012, 07:19 AM
BenJammin
1994 ZJ
So these past couple weekends there were a couple swap meets.... 2weekends ago I pick up a stainless skid plate and a KC lightbar and last weekend I grabbed up some Rubicon express extended stainless brake lines front and rear and a pair or kirky moulded bucket seats.. the light bar and skid were 10.00 each and the lines were 25(new in the bags) and the seats were 75... the app won't let me attach pics so I'll get some for y'all soon
BenJammin is offline
post #1072 of 2228 Old 11-07-2012, 07:23 AM
BenJammin
1994 ZJ
Ok so I guess it works... that one is of the skid here's the seats and lightbar... I also built a light bar for a buddy's ZJ for just over 50.00...
ForumRunner_20121107_082115.jpg   ForumRunner_20121107_082140.jpg   ForumRunner_20121107_082312.jpg
post #1073 of 2228 Old 11-08-2012, 12:01 PM
BenJammin
1994 ZJ
heres the kirkys installed
post #1074 of 2228 Old 11-08-2012, 03:40 PM
lord-steezus
Can you guys suggest what type of cb to get and antenna? I would like something around 4-5 feet
Sent from the best wheeling spot using my WJ
-Chris
02 wj
my build thread
lord-steezus is offline
post #1075 of 2228 Old 11-08-2012, 09:10 PM
Winners97TJ
Go Big Or Go Home
Winners97TJ's Avatar
I bought the Cobra 19 DX IV 40-Channel Compact CB Radio from Walmart for $50. (Actually $40 in store, if I remember correctly)
I ordered the 4ft. Fire stick and install kit from rightchannelradios.com for another $50.
Has worked out well for me so far. Helpful hint: order the sir meter with it so you can tune the antenna. It's only @$12.
Gun Control Means Using Both Hands
1997 Jeep TJ - Truly BUILT not BOUGHT! Purchased from original owner stock... obviously THAT didn't last long!
Winners97TJ is offline
post #1076 of 2228 Old 11-09-2012, 12:10 AM
DezertXj88
1990 XJ Cherokee
Originally Posted by murrdog66 View Post
My thoughts too!
Depends what you buy..I wasn't posting on the price I was posting because others mention LED lighting...which was also more than 100
post #1077 of 2228 Old 11-11-2012, 10:31 AM
RowJ
Final under armor item for my TJ...... Steering Box Skid.
Bgt in Oct Clearance Sale for $49.00 delivered.
Only hangs down 1/4" below steering gear box and is stout.
1.5 hr easy install, including drilling one 3/8" hole on backside of bumper frame.
Hardware included.......
RowJ is offline
post #1078 of 2228 Old 11-14-2012, 09:55 PM
KyleD31
I put a PA in (free). And an ooga horn in (free)
KyleD31 is offline
post #1079 of 2228 Old 11-17-2012, 12:16 PM
metalmulisha
less than 100
i took a 20 amp fuse plugged it into my (auto trans see owners manual) fuse slot i believe its slot #20 on a manual it allows you to start your jeep without pushing the clutch in i think this a a great mod cheap easy and now i dont have to crawl in and out everytime i warm her up in the morning
metalmulisha is offline
post #1080 of 2228 Old 11-17-2012, 01:24 PM
AZdEvilYJ
Ebrake and neutral do the same thing? Nonetheless, good discovery
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
cheap , cj
