I did this ________ for $100 OR LESS! - Page 53 - JeepForum.com
 8Likes
post #781 of 2228 Old 05-04-2012, 12:06 PM
BenJammin
1994 ZJ
Home depot special snorkel for 50.00
BenJammin is offline
post #782 of 2228 Old 05-04-2012, 12:47 PM
jamesdevore
Attachment 391924
Maybe it's just me but I think you'll have trouble drawing air though that design
/l ,[___],
l--L --OlllllO-
()_) ()_)-o-)_)
2000 TJ SAHARA - Black Jeep Society -
jamesdevore is offline
post #783 of 2228 Old 05-04-2012, 12:56 PM
Neoxxis
Not sure how big the oem air intake is on these Jeep's but on the JK it's a good 3"...
With such a small pipe it may have to suck hard to get the amount of air it needs...
07 Unlimited Rubi Rescue Green/Auto/pwr
Neoxxis is offline
post #784 of 2228 Old 05-04-2012, 02:54 PM
BenJammin
1994 ZJ
Its 2" and it seems to be okay... my TB is only 2.5" so its not to much restriction
post #785 of 2228 Old 05-04-2012, 10:12 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Bernoulli equation says you might be suffering more than you think you are.
Assuming:
-The air in your intake is incompressible
-Pressure at the TB inlet is approximately 50 psi
-Pressure at the inlet to your snorkel is 14.7 psi (atmospheric)
-Inlet velocity for the air is 10 ft/s (this value doesn't really matter for the answer--it's an arbitrary value)
If the OEM diamater is 2.5", then the area is 4.909 in^2
If your snorkel diameter is 2", then the area is 3.142 in^2
Bernouli's equation:
P2/density=P1/density+Velocity^2/2
Volume flow=velocity*area
The OEM inlet would get about 4230 CFM
Your snorkel gets about 2700 CFM, a reduction of about 40%.
That doesn't translate to a 40% reduction in power, but it doesn't really help. It's like your engine is sucking air through a normal straw instead of a McDonalds milkshake straw. It's just a little difference in size, but it makes a pretty big difference. Food for thought
In the garage: M1 4bbl
McCloudsZJ is offline
post #786 of 2228 Old 05-04-2012, 10:26 PM
toxikmo
^ which ammo can is that?
toxikmo is offline
post #787 of 2228 Old 05-04-2012, 11:17 PM
kjg26
kjg26's Avatar
Don't be silly. Mcdonalds gives you spoons for their milkshakes.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #788 of 2228 Old 05-04-2012, 11:34 PM
rdsk8ter
1982 CJ7
Assuming:
you lost me at assuming
here is my build threads
http://www.jeepforum.com/forum/f104/randys-offroad-trailer-1164102/
rdsk8ter is offline
post #789 of 2228 Old 05-05-2012, 03:47 AM
Thomahawk
Not in Norway.
Buildthread
Thomahawk is offline
post #790 of 2228 Old 05-05-2012, 03:59 AM
Shoot1stAskL8r
I'm not sure why (other than simplicity of the equation) you would ever assume that the air inside the intake is incompressible, because that's far from the truth. And showing a 40% drop of flow from 4500 CFM to 2700 CFM doesn't necessarily mean it will suffer, although that reduction would only be for a 2.5" to 2" inlet, the added bends in the pipe, plus the added friction down the length of the pipe could drastically reduce the true flow even further.. But IF at peak intake/RPMs the engine only required 1500 CFM in order to adequately perform, it may not matter whether he had a 3" open inlet or a 2" corregated pipe. Probably have to dyno it to know the true answer to whether there is any loss in power, but I'd say that if he runs it and doesn't have any noticeable change in power or fuel economy, it probably isn't that big of a hinderance on the engine.
Better to be Judged by 12 than carried by 6.
Shoot1stAskL8r is offline
post #791 of 2228 Old 05-05-2012, 02:26 PM
BenJammin
1994 ZJ
Well after 2 days and 300 miles... I've found that with the snorkel, and my high flow exhaust... I'm getting better mileage 300 mile on just over 2/3 of a tank, and I'm getting better power, both low end ans midrange, I no longer am pegged trying to keep a 50mph run up a long hill... it stays in OD AR about 2300rpm and even accelerates... I'm pleased with it... plus is sounds like a 12valve Cummins under heavy acceleration
post #792 of 2228 Old 05-06-2012, 01:10 PM
BenJammin
1994 ZJ
The best under 100.00 thing as of right now... was today picked ups gas tanks kid and tcase skid for 30.00... I pretty much stole them!
post #793 of 2228 Old 05-06-2012, 04:32 PM
stu132u
Keep us posted on the MPG's and performance of this snorkle. I actually have a design (patented) that doesn't require drilling in the side of the jeep.
stu132u is offline
post #794 of 2228 Old 05-06-2012, 04:37 PM
calrain07
Assuming:
Booyah!! PHYSICS
'05 rocky mountain edition....kc daylighters, 33x12.5x15 Duratracs, RC 3.25" SL, and 1.25" Spidertraxes
calrain07 is offline
post #795 of 2228 Old 05-06-2012, 07:37 PM
liveflatout
Got a RC dual steering stabilizer for $70.00 and broke it down and painted it with paint I had laying around. Will post pics when it is together tomorrow.
liveflatout is offline
cheap , cj
