I did this ________ for $100 OR LESS! - Page 129 - JeepForum.com
 21Likes
post #1921 of 2241 Old 04-16-2014, 12:28 PM
2000_limited
I know the little rubber bumpers are kinda cheap, but this was free so.
I had a rubber strip so I cut some off and made my own bumpers for the fuel door.
2000_limited is offline
post #1922 of 2241 Old 04-17-2014, 09:25 PM
Wat3rdog
Picked up some utility hangers at the store for a few bucks each and had some foam insulation for pipes to pad them for hanging my doors in the garage.
Grabbed some torx bits from Harbor Freight a while back and had been using a ratchet for the top but then thought of my cordless drill. Shaves about 10 min off my HT removal time.
Added some thin spot mirrors to my outer ac vents for the jk. They work great with my Rugged Ridge Mirrors (under $100 for both) . I have to have mirrors. It's an OCD thing for me.
I had an old tool box I snagged from work years ago laying around that I bolted to the rear of my JKU for small locked storage. Break down tools, cables, strap, ext.
Painted all the bright silver trim inside flat black. Couldn't take it anymore.
Wat3rdog is offline
post #1923 of 2241 Old 04-26-2014, 07:35 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Seat Reinforcement Brackets = $0
XJ owners have known that the seat base metal tears where it bolts to the seat track. After talking to a friend who has a WJ, he described a similar issue with WJ's. I'm assuming ZJ's have the same problem being as you can bolt WJ & ZJ seats to XJ seat bases.
I found this online, but didn't feel it was substantial enough.
http://www.jeepseatbracket.com/colle...eat-repair-kit
From there I decided to make my own kit out of 1/8" steel that I had kicking around. This can be bought at big box home improvement stores fairly cheap. I think I paid $20 for two 3"x36" sections of 1/8".
Typically, the seat bolts to the tracks with 4 bolts. But there is an additional bolt per side in the seat that is not used. Basically I made 6 plates that were drilled to match the 3 bolt holes per side. One plate is sandwiched between the seat track and the seat base on both sides, and a 3rd plate runs above the seat base on the outboard side, being as that's where the metal typically rips.
Template made out of cardboard.
Here they are almost cut out and test drilled. They may not be pretty, but after a wire brushing, and some paint, they should work out pretty good.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #1924 of 2241 Old 04-26-2014, 10:01 PM
TennesseeYJ
DIY hood lock to keep sticky fingers out! Use a short piece of 1" flat stock for an easy hood lock
I post the video link here, its easier that doing write ups
1991 Jeep Wrangler YJ, <-- My Jeep is a pickpocket!!
1984 Mustang GT Top 5-Speed <-- Running soon hopefully
2003 Honda Shadow Spirit 750, 1994 Suzuki Katana 600, 1980 Yamaha XS650 <-- Ripped apart and under the knife .. Chopped, bobbed & mono shocked. I got too many toy$$$!!!
TennesseeYJ is offline
post #1925 of 2241 Old 04-27-2014, 06:11 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
Must post a video of the sound
been a while, but here it is.
https://www.youtube.com/watch?v=gF9POm_doqQ
Total of just over $120 in the entire exhaust system. custom built headers for right about $60, then about $60 in materials in the rest of the system. muffler built of scrap material. behind a chevy TBI 350
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #1926 of 2241 Old 04-27-2014, 06:21 PM
ashland82391
That sounds great
ashland82391 is offline
post #1927 of 2241 Old 04-27-2014, 07:19 PM
squishy
That sounds great
Video says its a "k5". Thought maybe the motor was in a jeep at least.
Sounds great anyways. I wish my jeep sounded like that.
squishy is offline
post #1928 of 2241 Old 04-27-2014, 07:24 PM
underpowered
My DD is a jeep. but i wheel a K5.
i figured that this could easily be done for any vehicle even though i did it on a Non-jeep. I may even up building a muffler for my jeep since this one seemed to turn out well.
post #1929 of 2241 Old 07-26-2014, 07:37 AM
howtowrangler
Wrangler Grill Guards for about $10
Here is a link to the how to video: http://www.howtowrangler.com/?p=72
howtowrangler is offline
post #1930 of 2241 Old 07-28-2014, 03:00 PM
howtowrangler
Polyfil in the sound bar to enhance the sound
It costs about $10 (or less) and makes a big difference, here is a link to the how to video: http://www.howtowrangler.com/?p=31
post #1931 of 2241 Old 07-29-2014, 01:42 PM
Beatle405
http://www.jeepforum.com/forum/f46/i...l#post10185438
Has anyone else tried this? This post was from 2010 and I'm wondering if there are/have been any issues with it. Looks like a pretty cool mod.
Beatle405 is offline
post #1932 of 2241 Old 07-29-2014, 01:50 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I haven't done this yet, but I saw a land rover guy remove the guts from the schrader valve on his fuel rail and screw a T on it. On one side he has a pressure gauge, and on the other side he still has a schrader for bleeding off the fuel rail.
I'm considering doing this and it should be less than $20 in parts.
dagr8tim is offline
post #1933 of 2241 Old 08-01-2014, 11:08 PM
Dead_End
1990 XJ Cherokee
spent $70 in paint and $20 in tape and did this
[/Kevin]
_____________________________________________
Jurassic Park '90 XJ, '00 TJ
Dead_End is offline
post #1934 of 2241 Old 08-02-2014, 01:19 PM
ashland82391
Awesome! Wish it had been a xj instead of an Explorer
post #1935 of 2241 Old 08-02-2014, 06:37 PM
squishy
Thats a wild paintjob for a daily
Ashland is right. Looks much better on an xj.
Nice job.
squishy is offline
cheap , cj
