I did this ________ for $100 OR LESS! - Page 108 - JeepForum.com
 16Likes
post #1606 of 2232 Old 08-27-2013, 08:52 PM
Syncityj
Originally Posted by Perkalater79
Let us know how it goes. Do you think the bungee is tight enough so the load won't shift of fall off if tugged my a limb?
Ever since I have discovered ratchet straps I left bungees behind and never looked back.
Syncityj is offline
post #1607 of 2232 Old 08-28-2013, 12:29 AM
squishy
X10. Never again will I be whipped or stabbed by a bungee.
Probably sent from my couch cause I'm broke
squishy is offline
post #1608 of 2232 Old 08-28-2013, 05:06 AM
Winners97TJ
Go Big Or Go Home
Winners97TJ's Avatar
A very common thing to see in the ER for kiddos.... Lacerations of the face (and eyes) from bungees.
Gun Control Means Using Both Hands
1997 Jeep TJ - Truly BUILT not BOUGHT! Purchased from original owner stock... obviously THAT didn't last long!
Winners97TJ is offline
post #1609 of 2232 Old 08-28-2013, 08:53 AM
jasonswelding
They are pretty secure because they won't slip on the rubber surface. I've got a really short(broken) ratchet strap that I will probably use instead of the bungee.
jasonswelding is offline
post #1610 of 2232 Old 08-28-2013, 09:04 AM
humpty99
Front an rear stingers for free lol
humpty99 is offline
post #1611 of 2232 Old 08-28-2013, 09:14 AM
squishy
Eff you! That's the rear I want. How'd you get em free?
squishy is offline
post #1612 of 2232 Old 08-28-2013, 09:17 AM
humpty99
Built em myself. It's the only way to go
humpty99 is offline
post #1613 of 2232 Old 08-28-2013, 10:03 AM
8pitcher
8pitcher's Avatar
I'm going to build a genright carrier for my jk for about $100 later
8pitcher is offline
post #1614 of 2232 Old 08-28-2013, 02:25 PM
StuddMuffinz
Is the rear just attatched to the stock rear bumper?...
Y ~ N ~ W ~ A
StuddMuffinz is offline
post #1615 of 2232 Old 08-28-2013, 08:16 PM
humpty99
No built brackets to go to the hitch
humpty99 is offline
post #1616 of 2232 Old 09-01-2013, 12:01 PM
notjustone
a cpl different projects
new rear bumper= some 2x4x1/4 square tube that used to be a rack for holding steel been taking up space in my garage for 20 years (free) class 3 hitch off a truck I scrapped (free) d rings from harbor freight (5 bucks each)rustoleum bedliner paint. (15 bucks) and a licence plate light.(around 5 bucks at walmart)
http://i.imgur.com/t7UpDs6.jpg
http://i.imgur.com/qn5z1Xy.jpg
notjustone is offline
post #1617 of 2232 Old 09-01-2013, 12:05 PM
notjustone
front bumper
same square tube hf d rings. 130 watt lights (30 bucks off craigslist)
http://i.imgur.com/OasatgU.jpg
http://i.imgur.com/McNHjgl.jpg
post #1618 of 2232 Old 09-01-2013, 12:30 PM
notjustone
roof rack
some small chunks of diamond plate been laying around for 20 something years for rear brackets.(free) 2 10 foot pieces of 1 inch pipe from home depot (around 20 bucks)
http://i.imgur.com/f9Jvs3H.jpg
4 blazer 100 watt lights from walmart (50 bucks)
took rest of bedliner paint and dumped it right in with the remaining half gallon rustoleum black semigloss from a project a cpl years ago. wished I would have gotten new paint cause it was thick went on thick and caused a lot of crackling. but that would have put me over my hundred dollar budget.
all wire for lights and plastic wire wrap was free since the p.o. left the wiring harness from the plow he had on jeep.
wanted to locate the lights lower so I could put something longer then the rack on without hitting lights. so light mounts are unistrut (kindorf for the older guys)short chunks I got from work along with the 1 inch hanger straps. (free)
now look very close guys you tell me what the top rack section is made out of. think outside the box.
http://i.imgur.com/QGTf8j5.jpg
http://i.imgur.com/Gtp09ut.jpg
http://i.imgur.com/h5BQlk6.jpg
http://i.imgur.com/xtEbsRm.jpg
post #1619 of 2232 Old 09-01-2013, 12:33 PM
Maverickxeo
Top rack = futon?
Maverickxeo is offline
post #1620 of 2232 Old 09-01-2013, 12:42 PM
notjustone
winner winner chicken dinner 2 old futon frames picked up off craigslist for free. some will say its to thin ect ect ect but think about the weight they are made to handle I doubt ill have 500 or so pounds on my roof rack.
cheap , cj
